Hi i am struggerling to get mysql and php set up on my rasberry pi 3 b+
has anyone got a step by step guide on how this is set up please.
That kinda depends on which OS you are running on your RPi.
(2020-02-27, 13:20)Klojum Wrote: [ -> ]That kinda depends on which OS you are running on your RPi.
Hi at the moment i running OSMC
(2020-02-28, 01:33)YamYam Wrote: [ -> ]Hi at the moment i running OSMC
Have you tried asking at the OSMC forum?
OSMC seems based on Debian, so "apt install mysql php" ought to do it.
How au-fait are you with Linux systems? If you want phpmyadmin, you'll need to:
- install and configure mysql
- install then configure some webserver (apache, nginx, etc)
- install PHP and various extensions for your webserver
- download then configure phpmyadmin to listen to apache then instruct mysql
I'd also caution phpmyadmin has some exploits, so I'd recommend locking it down severely - preferably not exposing it to the interwebs.
Just curiously... why do you want phpmyyadmin installed on your media OS?
I am fairly confident with Linux i earn by following others or watching youtube videos.
My idea is this load Kodi up on my daughter's tablets give them both a custom skin use the raspberry pi along with MySQL so the raspberry pi acts as a server and a player if it is plugged into a tv.
the tables will be used for portable use for when on a plane or car etc.
I know you have the Kodi core app etc and yaste but I like the look of MySQL and the GUI that myphp admin provides. i know you have UPNP, but it does not
give the library view that you would normally get.
