Reviving, IMDB Trailers, an addon for watching trailers hosted by IMDb.
This addon was originally written by queeup and had been abandoned since 2013
I have revived it by rewriting the code to be Python 2 and 3 compatible and will run on all platforms starting from Kodi Leia upwards
NOTE - This will only work on Kodi 18 and above.
Dependencies: (Both available in Kodi repository and will auto install)
BeautifulSoup4
Requests-Cache
What is required on your part before posting a question
- If you find something not working then verify on IMDb website whether its working.
Install IMDb Trailers from Kodi Repository
You can also call this addon from other addons or in STRM files as below.
plugin://plugin.video.imdb.trailers/?action=play_id&imdb=
imdb_id
For e.g.,
plugin://plugin.video.imdb.trailers/?action=play_id&imdb=tt0113957
Enjoy!
Changelog
v2.1.12 (20200918)
api changes
v2.1.11 (20200516)
Add new api calls for categories
Fix occasional playback issues
v2.1.10 (29.02.2020)
[fix] Python2 syntax issue breaking on Kodi18
v2.1.9 (28.02.2020)
[fix] Playback shifted to HLS
[new] Search option
v2.1.8 (15.06.2019)
[fix] Rewrite using requests-cache module
v2.1.7 (1.06.2019)
[new] In Theatres and Coming soon sections
[fix] Python3 compatible
v2.1.5 (01.2.2019)
-Add view modes (Tested on Estuary Only)
v2.1.4 (08.12.2018)
-fix playback issue
-process html encoding
Currently there is a issue with search function. The search prompts for Keyboard input and upon entering movie name searches for the tile and lists matching titles. When you play one of the items, and finish, it prompt for Keyboard input again.
This behaviour is due to a feature introduced in 18.5 and above. The search function works correctly in 18.4 and below.
The issue is discussed in
this thread
I am struggling to overcome this in the newer Leia and nightly versions, but unable to do so myself and need some help in sorting this.
For now if you use the search function, the only way to safely go back to the main menu is to put a dummy search term again when it prompts second time and then when the directory listed press back to go to the main menu
Thank you for updating/fixing this!
(2020-05-10, 10:26)beatmasterrs Wrote: [ -> ]A user has a problem. He gets an error message every time he starts a trailer via the skin. Couldt you please help? Here's the original post (https://forum.kodi.tv/showthread.php?tid...pid2944731) log:
https://paste.kodi.tv/ufukebaden.kodi
For myself, the startup works via the skin, but not via the addon itself (only a few trailers are working and just a few categories).
https://paste.kodi.tv/eyebojequj.kodi
Can you take a look at this?
Thanks in advance
The first user problem you mentioned, unfortunately the log doesn't show any useful information as it is not a Debug log.
The Second issue of some trailers not working, is already fixed in the current git, will release it to Kodi repo soon
The reason I have not released to Kodi repo yet is because of another issue with imdb, they are experimenting a new api and due to that they keep changing the pages for Popular, Recent and TV Tonight trailer sections, every so often. So on some days it works and some days it doesnt. I was waiting for that to settle down to see which way they decide.
May be I will just release the playback fix for now and work on the sections in a later release.
This is a brilliant addon for my Arctic Horizon skin setup. Thanks for your good works. I'll be reporting any issues I may encounter.
beatmasterrs updated version released with playback fixes and category fixes, please check if you still have issues and report back if any.
(2020-05-24, 02:34)gujal Wrote: [ -> ]@beatmasterrs updated version released with playback fixes and category fixes, please check if you still have issues and report back if any.
For me, its working fine. Thanks a lot
Can you give some details on the API? Looking to call a category like "Coming Soon" and randomly play trailers until I hit stop or timeout? Is that possible?
dhogan
There is no documented imdb api, the addon is done by reverse engineering the imdb trailers website. Sorry couldn't be of more help
It looks like they've changed the IMDB interface again. My addon version is 2.1.11. Here's the exception:
2020-09-09 15:50:58.316 T:140173102806784 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.AttributeError'>
Error Contents: 'NoneType' object has no attribute 'get'
File "/home/my/.kodi/addons/plugin.video.imdb.trailers/default.py", line 23, in <module>
imdb_trailers.Main()
File "/home/my/.kodi/addons/plugin.video.imdb.trailers/resources/lib/imdb_trailers.py", line 77, in __init__
self.list_contents3()
File "/home/my/.kodi/addons/plugin.video.imdb.trailers/resources/lib/imdb_trailers.py", line 265, in list_contents3
videos = fetchdata3(key)
File "/home/my/.kodi/addons/plugin.video.imdb.trailers/resources/lib/imdb_trailers.py", line 577, in fetchdata3
data = data.get('recentVideos')
AttributeError: 'NoneType' object has no attribute 'get'
2020-09-09 15:50:58.408 T:140173094414080 ERROR: GetDirectory - Error getting plugin://plugin.video.imdb.trailers/?action=list3&key=recent
2020-09-09 15:50:58.421 T:140173824580800 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.imdb.trailers/?action=list3&key=recent) failed
Yes, they have changed the code again, have to wait for them to settle and will take a look at fixing
(2020-02-28, 14:16)gujal Wrote: [ -> ]You can also call this addon from other addons or in STRM files as below.
plugin://plugin.video.imdb.trailers/?action=play_id&imdb=imdb_id
For e.g.,
So I just read about this addon and had never heard about it before. My setup now uses the YouTube addon to play trailers but I'm curious about this one now. How exactly does this work with STRM files? Do you have to put the link as you mentioned in every movie and tv show NFO file manually? Or can it somehow be written in an xml file somewhere in the skin? Thanks
