2020-03-02, 10:24
Hey guys,
I really need your help to keep my WAF at a high level with kodi.
I have anĀ "SMSL dp3" that can be use with upnp /DLNA content.. if i use android app like "hificast" or "bubble upnp" i can send music from my kodi librairy to the DP3 via upnp/dlna.
But when i want to play music directly from kodi interface using the "play with" option , nothing happen if i send it to my DP3 or my "Denon AVR x4500H" in Upnp/DLNA but it's Ok with my TV "LG oled 55C7V"
My kodi is on an nvidia shield . I try to install kodi on my main computer on windows but ended the same way with nothing happening. Since it works to play on my TV the same way or with hificast i think there is no problem with my home network so i'm stuck.
I can post a log where i open kodi > try to play with smsl DP3 if needed.
Thanks in advance for your help
