When I go into add-ons and run update recently there are two add-ons with updates waiting but when I try to update I get this error:
"The dependency on xbmc.python 3.0.0 could not be satisfied"
I have been researching off and on for a couple of days and can't find an answer.........
Anyone have a solution?
(2020-03-04, 04:08)melons2 Wrote: [ -> ]I get the above mentioned errors in KODI 18.6
You did not mention that in your first post. At least tell us which three addons are causing you problems and provide a
Debug Log of you trying to update them.
Since 29 Feb, addons intended to be used in Kodi 19 Matrix nightly must specify in their addon.xml a dependency on Python 3.0.0. Addons which specify any Python 2.x.x will not install/update/run (even if they are compatible with both python versions). Python 2 addons should work in 18.6, and currently the plan is to have addons in the Kodi repo provide versions in the Leia (or "lower") repo and also in the Matrix repo (if updated to Python 3).
Update: I don't see any problem here on 18.6 installed on top of 18.5 (only had one addon to update which happened to be youtube alpha 2 and it updated with no issues). I installed the 0303 19 nightly over an older 19 nightly and a bunch of addons were disabled after first running the new nightly. I edited the addon.xml files for all the disabled ones (I've been doing some local updating of addons to Python 3 so I think they work) and re-enabled them all in Kodi 19.
scott s.
(2020-03-04, 18:10)scott967 Wrote: [ -> ]Since 29 Feb, addons intended to be used in Kodi 19 Matrix nightly must specify in their addon.xml a dependency on Python 3.0.0. Addons which specify any Python 2.x.x will not install/update/run (even if they are compatible with both python versions). Python 2 addons should work in 18.6, and currently the plan is to have addons in the Kodi repo provide versions in the Leia (or "lower") repo and also in the Matrix repo (if updated to Python 3).
scott s.
I understand now......
The two, not three, were really meant for Matrix with python 3.
Just for my own education:
How old is python 2.xxx?
How old is python 3.xxxx already?
Python 2 was released in the Year 2000 (16th October to be exact) and was EOL'd at the start of this year.
Python 3 was released in 2008 (3rd December) and is the currently active and supported one. Current stand-alone release version is 3.8.2 (released a couple of weeks ago), although various other versions are around and supported.
More details etc at
https://www.python.org/
(2020-03-04, 18:10)scott967 Wrote: [ -> ]I edited the addon.xml files for all the disabled ones
If I can ask, what changes need to be made to the addon.xml files? I'm also using a few addons with the latest Milhouse builds which auto-disabled and I'd like to try and get them working again.
I'm by no means a coder, but I've got a copy of Notepad++ installed on my Windows box and I'm not afraid to use it... :-)
Note: I'm talking about an addon or two that I believe are Python 2/3 compatible (Roosterteeth video addon for example).
From my understanding, changing <import addon="xbmc.python" version="2.x.x" />
(where 2.x.x is whatever version of Python 2 the addon requires) to <import addon="xbmc.python" version="3.0.0" />
in the <requires>
tag pair should do the trick, at least for any addon which is actually Python 2/3 compatible.
It won't of course magically make a Python2 only addon work with v19.
(2020-03-07, 09:54)DarrenHill Wrote: [ -> ]From my understanding, changing...
Thank you! I hoped that might be it, but wasn't sure. I'll try it this weekend.
(2020-03-05, 16:38)DarrenHill Wrote: [ -> ]Python 2 was released in the Year 2000 (16th October to be exact) and was EOL'd at the start of this year.
More details etc at https://www.python.org/
Hey. I have an nvidia shield with the latest kodi 19 matrix installed and I am trying to install the latest titan binji mod skin by achillespunks that is made for the 19 version. It keeps telling me the error that python 2.1.0 is not satisfied.. I really don't understand why can you help me with that please. Thanks
The section for the Titan skin and it's various mods is
here.
You're best off asking there, as obviously either it or more likely one of its dependencies is still using Python 2 and needs updating (or the correct version installing).
