2020-03-10, 07:02
Hi , i am from china。The HUAWEI Smatrt TV turns on kodi in a normal network environment and stops running after a few seconds。If you turn off WIFI or manually modify the gateway address to the wrong address, it will work normally。But Kodi 17.6 version can run normally on HUAWEI Smatrt TV ,Hope guys can help me analyze,Find out the cause of the problem。thank you very much! !! !!
