2020-03-10, 12:24
Is there PVR client allows to play or live stream a "non m3u" live TV ? if no, how do I include https in the kodi to launch it ?
(2020-03-10, 15:35)emveepee Wrote: [ -> ]There is a mechanism in NextPVR to record any URL that ffmpeg, vlc or other utility can transcode to mpeg ts via stdout. If the URL is not direct play you would need to create all the cookies, tokens, key files and credentials that you would need to pass to the utility since I suspect that is your problem, not https
Martin
(2020-03-10, 17:09)emveepee Wrote: [ -> ]Yes, if you are asking can you have an https URL in a strm file.
Martin
(2020-03-10, 17:07)FXB78 Wrote: [ -> ]"non m3u" doesn't tell us much, what is the format of your url?
(2020-03-10, 17:38)teamelite2019 Wrote: [ -> ]Assuming strm file allows me to key in the HTTPS URL of a Live TV, andthis is not a m3u, do I just type the URL in the strm file ?Yes just type it in and save it in the video library. You access the strm file through the folder in the Kodi video library.
How do I run or launch the strm file ? do you mind share me some steps
(2020-03-10, 17:40)teamelite2019 Wrote: [ -> ](2020-03-10, 17:07)FXB78 Wrote: [ -> ]"non m3u" doesn't tell us much, what is the format of your url?
Hi, what I meant was a Live TV, in which URL is not ended with M3U, it is a https URL, any clue to run it ?
(2020-03-10, 17:51)Shadow_GR Wrote: [ -> ]If you can't describe your problem, then, you'd better to upload one (or more) photos.for example
(2020-03-10, 19:04)FXB78 Wrote: [ -> ]Hi. thanks for your reply(2020-03-10, 17:40)teamelite2019 Wrote: [ -> ](2020-03-10, 17:07)FXB78 Wrote: [ -> ]"non m3u" doesn't tell us much, what is the format of your url?
Yes I got that, but you still haven't even told us what your url does end in, 'a https url' still tells us absolutely nothing.
(2020-03-10, 18:55)emveepee Wrote: [ -> ]Hi Martin(2020-03-10, 17:38)teamelite2019 Wrote: [ -> ]Assuming strm file allows me to key in the HTTPS URL of a Live TV, andthis is not a m3u, do I just type the URL in the strm file ?Yes just type it in and save it in the video library. You access the strm file through the folder in the Kodi video library.
Martin
(2020-03-11, 06:14)teamelite2019 Wrote: [ -> ]Ok. These are two websites with live streaming tv channels.(2020-03-10, 17:51)Shadow_GR Wrote: [ -> ]If you can't describe your problem, then, you'd better to upload one (or more) photos.for example
https://myklik.rtm.gov.my/live.php?ch=4
https://www.xtra.com.my/ms/livetv
(2020-03-11, 12:30)Shadow_GR Wrote: [ -> ]He wants to play the streams from those websites in Kodi.(2020-03-11, 06:14)teamelite2019 Wrote: [ -> ]Ok. These are two websites with live streaming tv channels.(2020-03-10, 17:51)Shadow_GR Wrote: [ -> ]If you can't describe your problem, then, you'd better to upload one (or more) photos.for example
And? What is your problem?
The TV SUKAN channel?
It will probably be temporarily closed.
I still don't understand you...
What do you exactly want?
