I'm rather new to Kodi, so I'm only now getting around to configuring the program. I recently added the Aura skin. I love the look and feel of Aura, but I don't see a power button on the main menu screen, and was wondering if the Aura skin doesn't have a power button by default, and whether a power button can be assigned to the menu screen. Any help on putting a power button for Aura on my main menu, would be appreciated. Thank you!
Thread moved to the Aura skin section
Check in the skin settings under customize home menu
(2020-03-13, 17:08)DarrenHill Wrote: [ -> ]Thread moved to the Aura skin section
On an unconnected note, kudos on your avatar. I was brought up on Roger Hargreaves and the Mister Men...
(2020-03-13, 17:07)cocopugg Wrote: [ -> ]I'm rather new to Kodi, so I'm only now getting around to configuring the program. I recently added the Aura skin. I love the look and feel of Aura, but I don't see a power button on the main menu screen, and was wondering if the Aura skin doesn't have a power button by default, and whether a power button can be assigned to the menu screen. Any help on putting a power button for Aura on my main menu, would be appreciated. Thank you!
Personally I never use a power button, long press on back button on remote from various screens brings up the shutdown menu. Much better option imo.
(2020-08-22, 21:07)ontap Wrote: [ -> ]Personally I never use a power button, long press on back button on remote from various screens brings up the shutdown menu. Much better option imo.
My remote doesn't do this.
I tired to add a keymap under global keyboard
<key id="61657" mod="longpress">shutdownmenu</key>
But that doesn't seem to work. Anyone have an idea to get it working?
(2020-10-04, 04:18)Nervosa Wrote: [ -> ] (2020-08-22, 21:07)ontap Wrote: [ -> ]Personally I never use a power button, long press on back button on remote from various screens brings up the shutdown menu. Much better option imo.
As has been posted above, in skin settings - "customise main menu" , in left column click on "+", in right column click on "choose item for menu" , scroll down and click on "Kodi Command" then select "quit".
(2020-10-04, 07:46)ontap Wrote: [ -> ] (2020-10-04, 04:18)Nervosa Wrote: [ -> ] (2020-08-22, 21:07)ontap Wrote: [ -> ]Personally I never use a power button, long press on back button on remote from various screens brings up the shutdown menu. Much better option imo.
I think you missed what I was trying to say.
On my remote (rii mx3) If I long press the back button nothing happens.
I was trying to add a command to keymaps to have this function.
