2020-03-15, 13:03
2020-03-15, 13:27
on windows all games are launched
2020-03-16, 00:33
(2020-03-15, 13:03)SoFuWa Wrote: [ -> ]No game starts on xbox one "This game isn't compatible with any available emulators"
Its on xbox, dont think any emus work. Easy topic for some quick research
2020-03-16, 09:46
(2020-03-16, 00:33)BoyBobby Wrote: [ -> ](2020-03-15, 13:03)SoFuWa Wrote: [ -> ]No game starts on xbox one "This game isn't compatible with any available emulators"
I just found an article on the Internet about it and did as it is written there. So this is possible.
2020-03-16, 10:48
https://www.libretro.com/index.php/retro...e-version/
2020-03-17, 17:06
(2020-03-15, 13:03)SoFuWa Wrote: [ -> ]No game starts on xbox one "This game isn't compatible with any available emulators"Do you have your ROMs and your videos in the same location?
That would help us to help you.
Regards.
2020-03-18, 17:38
(2020-03-17, 17:06)JustinC Wrote: [ -> ](2020-03-15, 13:03)SoFuWa Wrote: [ -> ]No game starts on xbox one "This game isn't compatible with any available emulators"Do you have your ROMs and your videos in the same location?
Regards.
ROM's online https://prnt.sc/rihhm3 not understood. setting not change, only run wizard
2020-03-18, 20:24
Why would you want to do this for in the first place?
As far as I am aware, that when you put an xbox in developer mode, it literally shuts down a lot of other features from working on your xbox.
You are spending hundreds of pounds or dollars or whatever currency, just to have an emulation box? You are better off just buying an android box such as the shield.
I would strongly advise you not to worry about playing retro games on an xbox unless they come from the store itself. You are risking your xbox putting it into developer mode.
2020-03-19, 00:08
Kodi for xbox (UWP) does not support Retroplayer since it's against the TOS for XBOX.
https://forum.kodi.tv/showthread.php?tid=337645
If you were super hard up to make it happen, you likely could compile it yourself, but thats a fairly involved science experiment and I wouldn't recommend it.
