Full Version: tvheadend configured, kodi doesnt play the shows - probably some very noob problem
I have got Raspberry Pi 4B with Libreelec (Leia, last version). I have installed and configured tvheadend server and installed the tvheadend client in Kodi. Everything looks smooth, I have got channels configured and numbered. Kodi shows the channels, numbers, their descriptions, the status of current broadcasted shows etc. I just cannot play any of the shows. When I click on any channel, it looks kinda like Kodi started playing it somewhere, as in the right upper corner I see the channel name and broadcasted show name with a small blue triangle (play sign), but thats it. No video, no sound. Any idea what might be wrong or how can I play the channels?
Thank you very much in advance for help. I have just started with raspberry/libreelec/kodi and I have very little experiance.
Nevermind, already fixed.
I've got the same problem. I found up to now no solution. Can you help?
(2020-04-26, 11:12)Equitania Wrote: [ -> ]I've got the same problem. I found up to now no solution. Can you help?
I believe I have fixed that by connecting the TV to the other HDMI socket. It should be the socket next to the power connector on Raspberry. Did it help?
(2020-04-26, 13:10)zakarumit Wrote: [ -> ]
Thank you for your answer, but that didn'n help me. I've that problem on all my devices: Windows, Android phone, Fire-TV-Stick. I found out, that this problem could be solved by editiing the file playercorefactory.xml. For windows it works fine now, I have to look now, how I edit the file under Fire-TV-Stick and Android.
(2020-04-26, 17:09)Equitania Wrote: [ -> ]Thank you for your answer, but that didn'n help me. I've that problem on all my devices: Windows, Android phone, Fire-TV-Stick. I found out, that this problem could be solved by editiing the file playercorefactory.xml. For windows it works fine now, I have to look now, how I edit the file under Fire-TV-Stick and Android.
Sorry, I am afraid I cant help you then. I havent done any file editing in my case...
