2020-03-16, 19:55
2020-03-16, 21:28
just install nasm via apt
2020-03-16, 21:43
If it's 18.04 then you can't get it via apt. 18.04 only has an older version. You have to download it from the focal ppa and install it with
sudo dpkg -i nasm-blah.deb
2020-03-16, 22:06
I will try to be clearer. 18.04 doesn't include 2.14 as it was added in v19. Should I download the 19.04 deb file or do I need to custom compile it?
Martin
Martin
2020-03-16, 22:18
You were perfectly clear the first time. Grab the .deb file from https://launchpad.net/ubuntu/focal/i386/nasm/2.14.02-1 then install it with dpkg
2020-03-16, 22:26
Ok that's the 20.4 one, I am not sure how to tell if different versions have different dependencies.
Martin
Martin
2020-03-16, 22:36
It doesn't. I had to install it the other day from that when dav1d got a version bump in master.
Although actually, on checking, the link I gave you was for i386 and you probably want amd64 the same as me. Package name that I installed was
xml:apt-cache policy nasm
nasm:
Installed: 2.14.02-1
Candidate: 2.14.02-1
Version table:
*** 2.14.02-1 100
100 /var/lib/dpkg/status
2.13.02-0.1 500
500 http://gb.archive.ubuntu.com/ubuntu bionic/universe amd64 Packages
2.11.08-1 500
500 http://ca.archive.ubuntu.com/ubuntu xenial/universe amd64 Packages
nasm_2.14.02-1_amd64.deb
Debian download page -> https://packages.debian.org/sid/amd64/nasm/download2020-03-16, 23:01
Yes thanks, once you said to try the deb I installed the correct package directly. No problem with the build after that.
Martin
Martin
2020-03-30, 11:23
the required build deps for 18.04 can be found in the kodi nightly ppa.
