On Kodi 18.6, I don't find anymore the option "automatic login on startup".
I've got two profiles, and I wish that "Master User" is the one which is always loaded on startup. How can I do that ?
(2020-03-20, 13:06)Groooompf Wrote: [ -> ]No one knows ?
I was wondering the same!
You figure it out?
(2020-05-02, 11:01)chrisvilla Wrote: [ -> ] (2020-03-20, 13:06)Groooompf Wrote: [ -> ]No one knows ?
You figure it out?
Got it.
Switch to the Estuary skin and then uncheck the "Show logon screen". Allows you to select the auto loaded profile.
(2020-05-02, 11:04)chrisvilla Wrote: [ -> ] (2020-05-02, 11:01)chrisvilla Wrote: [ -> ] (2020-03-20, 13:06)Groooompf Wrote: [ -> ]No one knows ?
You figure it out?
Got it.
Nice !
So, not every skin have the same options available ?
