Full Version: Music Smart Playlist with modified menus
I am using the Eminence skin on Kodi 18.6 (Android) but have completely customized the menus.  I don't see where I can create a music Smart Playlist.  I can create a video Smart Playlist via the context menu of the Playlists node under Videos.  That doesn't appear for Music (Playlists does, but the context menu has no New Playlist option).  So, is there a way to do it without adding a menu item and if not what menu item would I need to create?
Edit:  I found it.  Works differently than videos.  After scrolling to the bottom past my hundreds of playlists there is an option for new playlists.
Thread marked solved.
