(2020-04-05, 14:45)Publish3r Wrote: [ -> ]I did not watched WM 36 yet. I'm waiting until tomorrow, so i can watch the hole event.
But i'm confused that the livestream and wm are working now and the other stuff not.
Maybe the WWE changed something during the time they offers free content because of corona.
i don't have idea..... it's just for confirm.
the last lunartic version have Livestream works.. right now i'm stay to watch the live kickoff of part 2 of wm..
if i obtain some issue during full show i try to report feedback here....
(2020-04-10, 16:43)Publish3r Wrote: [ -> ]Maybe anyone can fix the addon with help of this code: https://github.com/freyta/WWE-Network-Downloader
This one seems to work.
I think the problem relates to the session not carrying over. That is why I created my own downloader. youtube-dl used to work, and then the requests library stopped working because it didn't carry over the headers or cookie/session.
Okay this seems to work for me. I no longer have a paid subscription, so I can't test other videos but a few of the WWE Top 10 and the WWE List This! episodes load fine
https://github.com/freyta/plugin.video.wwenetwork
I've submitted a pull request to the original creator too.
(2020-04-16, 10:08)Fbomb Wrote: [ -> ]Okay this seems to work for me. I no longer have a paid subscription, so I can't test other videos but a few of the WWE Top 10 and the WWE List This! episodes load fine
That works for me too. Thanks. But for the Shows (VOD) only. The Livestream is still not working for me.
Fbomb are you frayta? If yes, send me a pm please. I can give you my login data to fix the rest.
(2020-04-16, 11:30)Publish3r Wrote: [ -> ]That works for me too. Thanks. But for the Shows (VOD) only. The Livestream is still not working for me.
@Fbomb are you frayta? If yes, send me a pm please. I can give you my login data to fix the rest.
I can't message people because I haven't got enough posts. But if you have Twitter my handle on there is also Freyta..
(2020-04-16, 19:13)Fbomb Wrote: [ -> ]But if you have Twitter my handle on there is also Freyta..
I follow you now, but i can't write you a dm.
Publish3r - allow me to make things easier.
Fbomb - You now have PM priv's enabled.
(2020-04-16, 20:58)DarrenHill Wrote: [ -> ]@Publish3r - allow me to make things easier.
@Fbomb - You now have PM priv's enabled.
Thank you. I'll work on it a bit now and if needed over the weekend.
Edit: @
Publish3r, try pulling the updated code. The live stream now goes back up to 6 hours for me. You can rewind to anywhere on the scale and it works.
For some reason my streams are always pretty average quality, is it the same for you too?
Edit 2: Okay, there is an audio issue, it doesn't play it for some reason. I'll look into it a bit more
Edit 3: This seems to fix it for me. Open the context menu for the WWE Network addon click on "Settings". Go down to "Stream Quality", and click on "InputStream Addon Settings..." Then where it says "Stream Selection" put it on manual.
Now when you open a video it should play the audio automatically after a second or two. For me the default stream is "English - AAC - 0 Channels (3/16)". Let me know how you go
When I tried it last night I noticed that none of the episodes of NXT from this year were showing up, Think the last weekly episode that was showing up was early December last year.
Other than that & the live stream everything else I tried seemed to work.
(2020-04-20, 16:56)DjDiabolik Wrote: [ -> ] (2020-04-19, 13:59)Publish3r Wrote: [ -> ]I have a workaround for the livestream. I added an Australian Proxy Server.
https://github.com/Publish3r/plugin.video.wwenetwork
using a free proxy? it's not a slow connection respect an usage whitout proxy?
The default proxy is not a free proxy. It's a one month free trial. But you can use a free proxy, if you find a working one. The proxy solves the api requests, for streaming the proxy will not be used. That works with your normal ip.
I know it's not the best solution, but a working one.
I worked on another solution with a guy from the german kodinerds, but the test on windows failed. Maybe it could be a inputstream adaptive issue. I have to test it on Linux, but i have no Linux installed at the moment.
I hope that @
Fbomb will work on it.
(2020-04-20, 17:08)Publish3r Wrote: [ -> ] (2020-04-20, 16:56)DjDiabolik Wrote: [ -> ] (2020-04-19, 13:59)Publish3r Wrote: [ -> ]I have a workaround for the livestream. I added an Australian Proxy Server.
it's the proxy only used to obtain the url of livestream exact?
if yes it's can be used a service like hide.me or something similar...
Yes that's right it's for the API only. With the Proxy the API thinks that you are from Australia, India or Japan, that countries provides the old playlist url. USA / Europe are getting a other streamingserver und the playlist url has a different format. I guess it's the "Corona Server" to save some bandwidth.
Of course you can use @
Fbomb 's Version with a VPN (Australia, India or Japan. I don't know if there are other working locations). I tryed with NordVPN and it worked, too.
