I've no problem of playback with x265 video but when I want to go forward or backward, only sound moved and image still under search...
Finaly I can't move under x265 files..
Anybody have same problem ?
What's the solution ?
Thanks a lot..
The instructions are here...
debug log (wiki)
1.
Enable debugging in Settings>System Settings>Logging,
2.
Restart Kodi
3.
Replicate the problem.
4.
Upload the log to
Kodi Paste Site manually or use the
Kodi Logfile Uploader. (wiki) With either method post the link to the log back here.
If you are using the Advanced Method ensure you have correctly created and applied the
advancedsettings.xml file (wiki)
In both instances, you should see the word
DEBUG throughout the log.
Do NOT post your logs directly into the forum. Use the Kodi Paste Site. Post the link to your pasted log in the forum
Well I clarify the situation a little, when I play a x265 video and I want to advance for example at 30min, I have the sound advancing at 30min and the movie continues to play, the sound scrolls well but no image , she remained frozen on my request to advance to 30min.
No bug for kodi but in fact I've a problem..
So I tried with the new update, same result.
I want to send my log file but it is too large and I cannot put it on hastebin.
I have it on ubuntu paste
https://paste.ubuntu.com/p/PcHphcqkXn/
Is the War of the worlds video a HDR video perhaps?
Yes..
But same problem with another x265 files...
There are other reports with Rockchip devices on github as well.
Thanks, but what can I do for solve that.. I search on github but I don't find nothing...
You can debug it. Use adb and check where the issue is. Fixing non-standard-behaviour decoders is always a problem, especially if you don't have the HW or don't want to break valid firmwares, which happens from time to time, e.g. 18.6 broke perfectly working video on a wide range of devices cause we tried to solve a shortcoming of Philips TV firmware. Therefore our policy is more than ever: No hacks, no workarounds for non-standard-behaviour.
Yes.. Finally I go back to Kodi Leia the new nightlies and it's work fine... I will wait Kodi Matrix RC...
(2020-03-31, 11:51)fritsch Wrote: [ -> ]https://github.com/xbmc/xbmc/pull/15948/...22588a9cb2 rings a bell I tested that internally already / or better said made a build, but not sure about the results yet.
I can do another one, if someone volunteers testing.
If you can make a build with that commit reverted that would be great, I'll test it.
Seems that commit was added to help seeking on Phillips tv's, I don't know how their tv's pass Google CTS tests and get certified by Google since you read about Phillips tv's problems so often in the Kodi forum.
