2020-03-30, 19:16
Hello All -
I have recently bought a Sony Bravia 4K TV, this is a replacement to my previous (and now faulty) 1080p LG TV.
I am running Kodi v18.6 on top of an Intel NUC 8i3BEH, a reasonably good machine (a 2019 model) with Intel Iris Pro graphics (this is even more powerful than the new 10th gen Intel NUCs). I have Ubuntu 18.04 with a 5.3 Kernel. I have also updated the BIOS (to latest Intel version as per their website) and latest HDMI firmware (had to install Windows to install it, then put my Ubuntu image back on).
The problem I have is this:
If I run Ubuntu at its native resolution for the TV, so at 3840x2160p (4K), and run Kodi at that resolution, any videos that I have that are 1080p (which to be fair is most things) has fairly bad motion stutter. Any camera pans are jerky, and it feels like Kodi is struggling to "upscale" the footage smoothly.
I wonder if there are any settings that I should use within Kodi that would fix this?
Ideally there would be settings which people could recommend I try. I say this because firstly I'm sure I will watch some 4K videos through Kodi at some point and I would like to be able to enjoy them at their native resolution. I would like to leave Kodi on its "default" settings and have confidence that any 1080p video that I put through it will look good.
I tried a work around of setting Kodi to use the 1920x1080p setting. When I do this, the video naturally plays fine. However, if I put my TV to sleep, when I wake it up again it defaults back to the 3840x2160 resolution, thus making Kodi appear to take up 1/4 of the screen. I then struggle to get the software to perform because if I go back to the settings where I chose the resolution (Settings > System > Display > Resolution), it is still on 1920x1080 and so I have to try exiting the software and restarting it, and it's all just a hassle if I want to use the machine without a mouse and leave it as a media center (controlling it only with the Kodi remote on my iPhone).
I may try a hardware solution of using an EDID handshake emulator between the HDMI cable from the Intel NUC and the Sony Bravia TV, to force the NUC and the TV to see a 1920x1080p hardware limitation in each other. This may well work. But then, it will be a hassle when I want to come to watch videos that are 4K.
So I wonder if anybody could kindly recommend any settings that will help Kodi to playback (like I said, possibly "upscale") the 1080p videos smoothly? A nice software setting that I haven't seen or considered would be ideal....
(Just for clarity's sake, I can set both the Ubuntu to a display setting of 1920x1080 resolution, and the Kodi to 1920x1080, and send my TV to sleep, and when I wake the TV up, all I see is the Kodi a quarter of the size of the screen as I previously said.)
Thanks very much to everybody who has taken the time to read this - I wish you to stay healthy through this Coronavirus situation.
Best regards.
Best regards.
