Full Version: Difference: videodb://movies VS library://movies
Hi.
I'm setting up Movies main menu item and got a problem. I'm using Kodi 18.6 in Android TV.
By default, it points to videodb://movies. But, I need to put a rule in movies node so it doesn't show music concerts (added as movies). I put the rule in the node (not show if path is...).
If I let it point to videodb://movies, rule doesn't work as it is in the node, so I have to point the menu item to library://movies instead.
Is there any problem doing that? Is it the same for perfomance? What ill be the difference between one and the other?
Not sure if this go in this forum, so sorry if I put it wrong here.
Thanks Smile
No.
library://movies is to replace videodb://movies etc. The process is just not complete.
eg. https://github.com/xbmc/xbmc/pull/16995
(2020-03-30, 22:06)LongMan Wrote: [ -> ]No.
Great, thank you mate Smile
