Hello,
Little feedback to kodi team, current build of Alpha Kodi 19 have issue for opening ISO file (source with IP).
Same issue on Windows (see signature) and Android (Galaxy Tab S5e)
Error on log : XFILE::CFileFactory::CreateLoader - unsupported protocol(udf)
Thank for futur fix.
(2020-03-31, 10:08)kalima Wrote: [ -> ]current build of Alpha Kodi 19
When you are using nightly/alpha builds, it's best to mention the build(s) or version(s) of Kodi that you are using.
In a month's time, your thread will be useless because no one knows which build(s) you used.
(2020-03-31, 10:08)kalima Wrote: [ -> ]Error on log : XFILE::CFileFactory::CreateLoader - unsupported protocol(udf)
Single lines from the Kodi log are not considered a log submission.
We prefer to have all the puzzle pieces as in the full log file, not just one puzzle piece.
Yes, "little" feedback it is.
Klojum : Sorry first log upload for me
My current Build is last version: 30 march 2020: KodiSetup-20200330-24970948-master-x64.exe
I tested on my primary computer:
CPU : AMD Ryzen 3900x
GPU : AMD Vega 64 (Drivers 20.3.1)
Sound : Creative Sound Blaster AE-9 (direct sound)
Log :
https://paste.kodi.tv/bufijavobi
Same error on my tablet S5E (android 9) , my htpc (signature) with 30 march build.
Are you a regular user of Nightly builds? if so what date was the last working one for you?
Going by error message posted then there's a chance it maybe due to
https://github.com/xbmc/xbmc/pull/17447 if it was this then I'd expect Nightly from 11th March to work for for it to break with build from either 12th or 14th.
I don't make update every day but every month with video drivers. February build work perfectly (21 february build)
You want a test with Build 11th March ? I can make a downgrade on my current build ?
If you don't mind putting the work in, could you first downgrade to the build from the 14th March to see if that is still not working then grab a debug log with this build. Then downgrade again to the 11th March build to see if that is working, then if my suspicion is correct and it is working then grab a debug log showing it working. Once you've done this and have the debug logs then please create an Issue at
https://github.com/xbmc/xbmc/issues and be sure to include the debug logs.
Thank JJD-UK,
Issue opened with all log (
https://github.com/xbmc/xbmc/issues/17588) , you have enough information ? (it's my first issue submission)
KodiSetup-20200330 : Issue
KodiSetup-20200314 : Issue
KodiSetup-20200311 : Issue
KodiSetup-20200310 : Issue
KodiSetup-20200301 : Work
Thanks for that, although it appears my guess was wrong there's been several changes surrounding the code for ISO handling, all of which were subsequent to the 1st March.
