In the compile how to documentation in Leia there is no mention at all about how to compile it using Python 3.
I would be interested in such a subject. Any pointer?
I don't think that's an option (at least not anymore). I vaguely recall (and might be wrong) very, very early in the Kodi19 development there were options to build Kodi18 with Python3, but that was just an interim thing until Kodi19 was stable enough for testing. I think the only option now for Python3 support is to build Kodi19 (or use one of the nightly builds).
WHY??. This build is 100% useless as it has xbmc.python compat at 2.1.0 and install addons from the Leia repo which are meant for py2. Even if you somehow fix it to have xbmc.python 3.0.0 you will need to backport ALL the changes in matrix for addons to work properly. Distros should not add useless patches that break upstream.
I use Arch LInux BTW.
fedora users will be happy to have almost all a lot of addons broken
Not to mention that such a kodi binary is unsupported here
(2020-05-04, 21:47)mooninite Wrote: [ -> ] (2020-05-03, 20:57)V8MEM Wrote: [ -> ]WHY??. This build is 100% useless as it has xbmc.python compat at 2.1.0 and install addons from the Leia repo which are meant for py2. Even if you somehow fix it to have xbmc.python 3.0.0 you will need to backport ALL the changes in matrix for addons to work properly. Distros should not add useless patches that break upstream.
https://fedoraproject.org/wiki/Changes/RetirePython2
That page would seem to indicate Kodi 18 is fine. It uses it's own internal Python 2.7 package, which is specifically called out in the link you provided.
https://fedoraproject.org/wiki/Changes/R...27_package
Look, we should definitely get Kodi to Python3, but Kodi 19 is that path. If someone has time to try and recompile Kodi 18 with Python3 support, backport the changes to get it working, and manage a set of addon repos specifically for Python3 packages for Kodi 18, then maybe, just maybe, they have time to help get Kodi 19 out the door.
