Full Version: Problem with TheMovieDB scraper not parsing letter "ñ"
Hi.
Using TheMovieDB scraper, it seems not to parse the name correctly to TMDB if it contains "ñ" character (is a Spanish letter).
Tittle example: "11D: Una mañana de invierno".
If I rename the mkv file from "mañana" to "manana", then it works, so I think, the scrapper is not sending the character "ñ".
@TassMetal
It works for me. Did you name your folder and file as ... 11D Una mañana de invierno (2017)
(2020-04-02, 20:43)Karellen Wrote: [ -> ]@TassMetal
I had it named "11D - Una mañana de invierno (2017)", naming it without the - did work.
I don't understand why it failed before as I use - to replace every : in names and has always worked with the rest of the movies. And neither I understand why with - in the tittle it did scrape it right if I write "manana" instead of "mañana".
Any way, its solved, thanks a lot Karellen and sorry for your item.
