2020-04-04, 23:41
I want to start using playlists.
I see some things which are unintuitive for me and I want to know, whether it is possible to change the behavior:
- First and the most important: in list editor I need to use context menu to add a song from left panel to the list (on the right). In my opinion it should be added by click/enter/OK on remote, so it should be the main, default action in this place.
- Editing the already existing list is also not comfortable. I've found such way: go to the lists menu, choose New list (instead of the one you want to edit!), then click Open and navigate to your list. In my opinion click (or keypress another default key) on the list should play it or edit (or just ask, like in already started movies watch from begining or a moment of pause). Now it brings me to some kind of list preview, where I cannot edit it or clearly start to play it. Of course both actions are in context menu, but it is not comfortable.
Is this possible to change this things, especially the first one? I'm not asking for 'fix', because it may be expected behavior for others. But I don't want to worry about clicking and starting a song instead of adding it to the list.
