Full Version: missing dependency with 2.1a2svn14555-hardy1 PPA build
just installed the newest PPA and XBMC wouldnt start up after that
got this when i tryed to run it in terminal
/usr/share/xbmc/xbmc.bin: error while loading shared libraries: libfaac.so.0:
i just searched for libfaac in synaptic and installed it and now it works again.
You might wanna add this as a dependency or else it wont boot. Wasnt a problem in older builds.
Thank you for this information
I'll change it
I installed fac and that fixed it (but it should be a dependency since the program won't even launch without it.)
Are you moving dependencies to the distro rather than the precomplied ones that comes with XBMC?
If so, I think that is a marvelous change.
We have to precompile libs so they can be wrapped to access our virtual file system and/or we can track their memory usage and various other stats. However, we have done away with versioning these libs in SVN in favor of compiling them with XBMC.
JackieBrown Wrote:I installed fac and that fixed it (but it should be a dependency since the program won't even launch without it.)
I have done the change, you should normally have it in
xbmc - 2.1a2svn14555-hardy2, xbmc - 2.1a2svn14555-gutsy2, xbmc - 2.1a2svn14555-intrepid2, xbmc - 2.1a2svn14555-feisty2
