(2019-09-11, 17:28)V8MEM Wrote: [ -> ]YouTube just disabled all 3rd party apps from viewing videos
https://github.com/TeamNewPipe/NewPipe/issues/2615
Damn, that really sucks. I just started encountering the "No streams found" issue a little while ago. I hope someone can manage to get the add-on functioning again.
(2019-09-11, 17:42)NeoCortex Wrote: [ -> ] (2019-09-11, 17:28)V8MEM Wrote: [ -> ]YouTube just disabled all 3rd party apps from viewing videos
Looks like YTDL already has a quick fix available, so the addon should be fixable.
Hiii. Someone please help. Is that true that youtube stopped third party apps like Kodi?!!! I just decided to use Kodi youtube add-on to watch the videos because its more beautiful and modern for me to use it instead of a regular browser.
Tried everything like API settings or sign in but none of them worked.
Is there a way??!!!
(2019-09-11, 18:05)lordvandad Wrote: [ -> ]Hiii. Someone please help. Is that true that youtube stopped third party apps like Kodi?!!! I just decided to use Kodi youtube add-on to watch the videos because its more beautiful and modern for me to use it instead of a regular browser.
Is there a way??!!!
They stopped the 3rd party apps several times before by simply making their servers speak a totally different language which the 3rd party apps don't understand yet (that's why we all see the
No streams found error) and need to be fixed, the devs are usually very quick at figuring out the new language
anxdpanic is already aware and looking into this issue.
Please standby until a fix is found.
THANKS
roman_mzv
I tried adding some protection against this, not sure atm why it's only happening to you.
Han Solo
userdata (wiki)/Database/MyVideos###.db
och29
Haven't found a possible cause yet
Mashiro-sama
I think some work is required and being done in Kodi 19 for this.
lysyi
Yes, perform the search in the YouTube addon with
debug log (wiki) enabled, and you'll see the url used in the log.
muriloferraz
In this rare case use;
import xbmc
xbmc.executebuiltin("RunPlugin(plugin://plugin.video.youtube/play/?playlist_id=PLn9tst_548zXssIHOo9f5H3p_gkfpojOT&order=shuffle&play=1)")
Jester
It is, example usage of that module is
https://github.com/jdf76/plugin.video.yo...g.txt#L336
eusergiofontes
It should work, would need a
debug log (wiki) and example playlist to look into it further.
Sorry if I missed anyone, please try 6.5.2~beta2
(see below) and if the issue persists please @ me with a new
debug log (wiki)
I've updated post
#2 and the
repositories with v6.5.2~beta2
[fix] playback (No streams found)
[fix] missing metadata
[fix] check for and convert unexpected timestamp format
Updated the add-on and everything is working great on my system now. Thanks for the effort and quick response in fixing it.
(2019-09-11, 21:29)anxdpanic Wrote: [ -> ]@roman_mzv
@Han Solo
@och29
@Mashiro-sama
@lysyi
Yes, perform the search in the YouTube addon with debug log (wiki) enabled, and you'll see the url used in the log.
@muriloferraz
import xbmc
@Jester
It is, example usage of that module is https://github.com/jdf76/plugin.video.yo...g.txt#L336
@eusergiofontes
It should work, would need a debug log (wiki) and example playlist to look into it further.
Sorry if I missed anyone, please try 6.5.2~beta2(see below) and if the issue persists please @ me with a new debug log (wiki)
I've updated post #2 and the repositories with v6.5.2~beta2
Wow! Thanks for the very quick fix!
I don't understand how to fix my youtube with this information. I am a newbie so please be patient with me.
(2019-09-11, 22:30)Sobersally Wrote: [ -> ]I don't understand how to fix my youtube with this information. I am a newbie so please be patient with me.
add beta repo in addons and will automatically update to the latest beta
github
updated and fixed "no streams available"
yall are the best, thank you!
