2019-09-21, 16:06
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189
2019-09-21, 19:51
(2019-09-21, 15:32)anten.puzl Wrote: [ -> ](2019-09-19, 06:43)neo_ Wrote: [ -> ](2019-09-19, 06:20)neo_ Wrote: [ -> ]Same exact problem here. Running Leia on CoreELEC all the newest stable. Been happening for a day or two now.Update: FIXED issue by enabling mpeg-dash videos. I previously only had it enabled for Live videos.
(YouTube Settings --> MPEG-DASH --> "Use for Videos" needs to be enabled
Have same problem. But this switch not aviable and i cant change it. How to fix?
I wondered too but you need to install another addon to enable it. I installed it and then I could enable dash in the settings in the yt addon
https://kodi.wiki/view/Add-on:InputStream_Adaptive
2019-09-21, 20:11
(2019-09-21, 19:51)brainwaster Wrote: [ -> ]thanks. now its ok.(2019-09-21, 15:32)anten.puzl Wrote: [ -> ](2019-09-19, 06:43)neo_ Wrote: [ -> ]Update: FIXED issue by enabling mpeg-dash videos. I previously only had it enabled for Live videos.
2019-09-21, 21:40
(2019-09-21, 16:06)mfck Wrote: [ -> ]Hi, everybodyI use 'vi' to edit the ~/.kodi/userdata/addon_data/plugin.video.youtube/settings.xml and api_keys.json files...
Is there a way to configure the API keys of the add-on via ssh, i.e with command line?
Thanks in advance
2019-09-22, 00:54
(2019-09-21, 21:40)Yubby Wrote: [ -> ]Thanks, that was it.(2019-09-21, 16:06)mfck Wrote: [ -> ]Hi, everybodyI use 'vi' to edit the ~/.kodi/userdata/addon_data/plugin.video.youtube/settings.xml and api_keys.json files...
Thanks in advance
Now who will be kind enough to explain to me how to enable the HTTP Server that MPEG-DASH demands to work, please?
2019-09-22, 11:47
The plugin (6.5.1. as well as 6.5.2 beta3) started to crash on me throwing Python errors. Basically it refuses to work at all. Is it the plugin or is it Libreelec? Log below
2019-09-22 11:40:32.665 T:2391483248 ERROR: GetDirectory - Error getting plugin://plugin.video.youtube/special/new_uploaded_vi
deos_tv/?reload=2019092209154020190922093849
2019-09-22 11:40:32.906 T:2493186928 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the f
ollowing error<--
Error Type: <type 'exceptions.ValueError'>
Error Contents: Extra data: line 19 column 4 - line 20 column 2 (char 921 - 924)
File "/storage/.kodi/addons/plugin.video.youtube/resources/lib/default.py", line 1
2, in <module>
from youtube_plugin import youtube
File "/storage/.kodi/addons/plugin.video.youtube/resources/lib/youtube_plugin/yout
ube/__init__.py", line 11, in <module>
from .provider import Provider
ube/provider.py", line 21, in <module>
from ..youtube.client import YouTube
ube/client/__init__.py", line 11, in <module>
from .youtube import YouTube
ube/client/youtube.py", line 16, in <module>
from .login_client import LoginClient
ube/client/login_client.py", line 17, in <module>
from .__config__ import api, youtube_tv, developer_keys, keys_changed
ube/client/__config__.py", line 221, in <module>
_api_check = APICheck(__context, __settings)
ube/client/__config__.py", line 30, in __init__
self._am_jstore = LoginTokenStore()
File "/storage/.kodi/addons/plugin.video.youtube/resources/lib/youtube_plugin/kodi
on/json_store/login_tokens.py", line 17, in __init__
JSONStore.__init__(self, 'access_manager.json')
on/json_store/json_store.py", line 34, in __init__
self.load()
on/json_store/json_store.py", line 54, in load
data = json.load(jsonfile)
File "/usr/lib/python2.7/json/__init__.py", line 291, in load
File "/usr/lib/python2.7/json/__init__.py", line 339, in loads
File "/usr/lib/python2.7/json/decoder.py", line 367, in decode
ValueError: Extra data: line 19 column 4 - line 20 column 2 (char 921 - 924)
2019-09-22 11:40:35.973 T:2374697840 ERROR: GetDirectory - Error getting plugin://plugin.video.youtube/channel/mine/playlist/L
LoMCgJ1EA435VifUa3S--MA/?reload=2019092209154020190922093849
2019-09-22, 12:23
2019-09-22, 12:25
The instructions are here... debug log (wiki)
1.Enable debugging in Settings>System Settings>Logging,
2.Restart Kodi
3.Replicate the problem.
4.Upload the log to Kodi Paste Site manually or use the Kodi Logfile Uploader. (wiki) With either method post the link to the log back here.
If you are using the Advanced Method ensure you have correctly created and applied the advancedsettings.xml file (wiki)
In both instances, you should see the word DEBUG throughout the log.
Do NOT post your logs directly into the forum. Use the Kodi Paste Site. Post the link to your pasted log in the forum
2.Restart Kodi
2019-09-22, 17:31
2 Q about the use of the addon.
1) Can I make a search with duration ? How I limit a search results to only 30 min and up videos? or any additional parameter.
2) Why the search results in the addon are different than the ones in the YouTube app?
I found few videos in the app but they are not at all in the addon search results.
Thank you.
Thank you.
2019-09-22, 19:32
(2019-09-22, 12:25)DarrenHill Wrote: [ -> ]To receive meaningful assistance you will need to provide a full debug
Sure, I acted like a total moron, sorry . Here's the log (turned Debug Log on, restarted, tried to fire up YT, plugin crashes at log line 1340, reboot again): https://paste.kodi.tv/iqajasidos.kodi
2019-09-23, 10:45
Hi!
I'm trying to play with an external player, and in the settings there's this option:
Settings=>Advanced=>Support alternative player
It does work fine, but not with MPEG-DASH enabled,because it loops it to the inputstream adaptive addon,(I think)
example; "http://127.0.0.1:50152/Cln0J87vulU.mpd"
The Retrospect addon does send the mpd to the external player, and it works fine.
I wish the youtube addon could do the same, as my external player supports it.
2019-09-24, 00:34
(2019-09-22, 17:31)asik1 Wrote: [ -> ]2 Q about the use of the addon.
Thank you.
Specify 'Youtube app" ? (do you mean web browser ?)
2019-09-24, 09:32
(2019-09-24, 00:34)Yubby Wrote: [ -> ]No, there is android YT app.(2019-09-22, 17:31)asik1 Wrote: [ -> ]2 Q about the use of the addon.
Thank you.
https://play.google.com/store/apps/detai...id.youtube
I think the the addon is based on it, isn't it?
2019-09-24, 09:39
(2019-09-24, 00:34)Yubby Wrote: [ -> ](2019-09-22, 17:31)asik1 Wrote: [ -> ]2 Q about the use of the addon.
Thank you.
And it gives different search results.
2019-09-25, 19:57
I've been getting the following while trying to play some of the videos on my Watch list.
Similar posts on this thread recommend installing a 6.0 beta version to fix this issue but I'm on 6.5.1 and still getting this. My google searches suggest that the reason is my old Kodi version (I have one Android TV box where I can't install a more recent release) but this only seems to happen with some of the items on my watch list and only when I try to watch them in HD, I can still play them in SD or audio only. Is there a known fix for this? Was the fix included in that beta removed at a later date for some reason?
txt:13:02:27 T:1970706912 NOTICE: [plugin.video.youtube] Running: YouTube (6.5.1) on Jarvis (Kodi-16.1) with Python 2.6.5
Path: /play/
Params: {'video_id': 'AT2wzQq7kx0'}
13:02:27 T:1970706912 ERROR: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.module.requests/lib/requests/packages/urllib3/util/ssl_.py:335: SNIMissingWarning: An HTTPS request has been made, but the SNI (Subject Name Indication) extension to TLS is not available on this platform. This may cause the server to present an incorrect TLS certificate, which can cause validation failures. You can upgrade to a newer version of Python to solve this. For more information, see https://urllib3.readthedocs.io/en/latest...l-warnings
SNIMissingWarning
