(2020-02-19, 23:38)zoli289 Wrote: [ -> ] (2020-02-19, 22:48)speedwell68 Wrote: [ -> ] (2020-02-19, 20:04)zoli289 Wrote: [ -> ]Thank you, it works.
I followed the steps to generate those 3 keys.
Started my media player, enter youtube addon settings, switched OFF "use developer keys" and switched ON "enable personal keys".
Then entered 3 keys. (man, doing that with the IR remote and onscreen keyboard, was more than 10 mins!).
Pressed Ok, and it works!
And indeed, no need to login to youtube.
THANK YOU!
I never login on Kodi either. I just use it as a cast receiver from any of my devices. I gave trying to enter those keys in the UI and just did it in the terminal.
As an aside, is there a way to paste something into the Kodi UI?
Easier if you just edit the settings file on your player from your PC via network: \Userdata\addon_data\plugin.video.youtube\api_keys.json
I just added my credentials to the file in the Kodi install on my Linux desktop in Nano and copied the modified file to my Raspberry Pis running LibreELEC using SSH.
Was wondering if someone could confirm sending JSON-RPC commands to this plugin works?
I've tried sending a curl command but no video plays and the logs are not clear on whether or not JSON-RPC is supported.
log:
https://paste.kodi.tv/ujerawuhuz.kodi
command:
curl -s --data-binary '{"jsonrpc":"2.0","id":"1","method":"Player.Open","params":{"item":{"file":"plugin://plugin.video.youtube/play/?v ideoid=aeur4AZRbcw"}}}' -H 'content-type: application/json;' http://192.168.0.108:8080/jsonrpc
Much appreciated
helloo all
i have been using the YouTube add on in its vanilla configuration since i have been using xbmc. recently i have updated to 18.5 and all worked well on all my machines until Tuesday night.
now i get an error to configure the add on and that project 294899064488 the project is scheduled for deletion.
i uninstalled the YouTube add on and re-installed the latest version it to no avail.
what happened and what should i do?
thank you in advance
BikerDude - I've merged your post into the proper YouTube addon support thread where it should be.
Read back over the last few pages for an explanation of the current situation and what you should do (personal API keys, also see the first few posts of this thread).
i may be wrong with this how safe is this addon could it have been hijacked ?
plugin.video.youtube\resources\lib\youtube_plugin\youtube\client
login_client.py
xml:
'service': 'oauth2:https://www.googleapis.com/auth/youtube '
'https://www.googleapis.com/auth/youtube.force-ssl '
'https://www.googleapis.com/auth/plus.me '
'https://www.googleapis.com/auth/emeraldsea.mobileapps.doritos.cookie '
'https://www.googleapis.com/auth/plus.stream.read '
'https://www.googleapis.com/auth/plus.stream.write '
'https://www.googleapis.com/auth/plus.pages.manage '
'https://www.googleapis.com/auth/identity.plus.page.impersonation',
a google search for
http://googleapis.com, a malicious site, is a tech scam support, created by cyber criminals to scam victims' money via showing bogus security alert and luring you into using provided paid online services. Usually, adware or malware can be conducive its appearance in your computer.
Storage.googleapis.com is a type of website that can implement a drive-by-download scheme in order to infect visitor's computer. ... Malicious site like Storage.googleapis.com is known for distributing various kinds of adware, malware, and potentially unwanted program.
thank you for your reply
i tried both links to no avail both said page not available. I do not use my htpc to surf strange websites nor do i use it to read mails. so how can it be hacked?
what should i do with the code you provided?
ran windows defender to no avail
(2020-02-18, 13:44)gsg2000 Wrote: [ -> ] (2020-02-18, 02:28)ESCO1 Wrote: [ -> ] (2020-02-17, 21:10)rykios Wrote: [ -> ]From the kodi logs:
ERROR: [plugin.video.youtube] Error reason: |accessNotConfigured| with message: |Project 294899064488 has been scheduled for deletion and cannot be used for API calls.
Visit https://console.developers.google.com/ia...etion=true to undelete the project.|
Looks like addon problem with google. The author hopefully can take care of it
Am getting the same error. So is this normal for everyone? Is the addon have problems and this is something the author needs to fix?
Same problem here. Haven't been using API though. I guessing the author will need to fix it. OMG!
update created API works great now. My Bad!
hello all
i have read the above posts, and tried to follow the links with no results. i am not a programmer nor an IT savvy person. As i go to the links i get to a dashboard with no reference to the steps mentioned. beginning to be frustrated with this process.
Can some one please assist
Thank you
Don't know if posted or mentioned so far, but here is an easy and temp fix for now
Click on 'settings' -> add-ons -> my add-ons -> video add-ons -> YouTube.
Click the 'configure' button.
Highlight 'API' on the left. You will now see some settings on the right. Turn OFF 'Enable personal API keys' if it is enabled. A setting called 'Use preset API key set' will appear. Click the up/down arrows until it says '5'. Click OK. Enjoy you-tube until that set of keys are disabled.
(2020-02-20, 17:00)BikerDude Wrote: [ -> ]hello all
Thank you
Same problem here, for all "real world users" I suggest marking this addon as broken.
(2020-02-20, 19:49)DJB628 Wrote: [ -> ]Don't know if posted or mentioned so far, but here is an easy and temp fix for now
Go into YouTube Add-on settings > API > disable personal API keys > use preset API key #5
hi folks
if i go to YouTube Add-on settings > API > disable personal API keys > use preset API key #5 i cannot get access to API. once this is clarified
what do you mean use preset api key '5
thanks
(2020-02-19, 16:38)SmellyCat Wrote: [ -> ]Hi.
I created my personal API keys.
However after signing in with the google.com/device I get the following error:
Error Contents: Error reason: |accessNotConfigured| with message: |Access Not Configured. YouTube Data API has not been used in project 68470048244 before or it is disabled. Enable it by visiting https://console.developers.google.com/ap...8470048244 then retry. If you enabled this API recently, wait a few minutes for the action to propagate to our systems and retry.|
Everything looks fine in the dashboard. The API key is enabled. I waited half an hour already, but every time I start the youtube addon I get that error now.
Did I forget something?
Answering to my own question...
Always create a new project in the google dashboard. I used an old project and google automatically reduces the quota to 0 after a period of inactivity without the ability to increase it.
I got it working now.
