Hi there,
I'm still getting 'LoginException: [401] invalid_client Invalid Client Type' error msg on screen and can't work out why.
Is anyone able to work through checking settings with me please?
How can I find some logs that will help to get the bottom of this issue?
Kodi YT Add-on version 6.6.0. OSMC January 2020 2020.01-2 Rasp Pi 3b
Thanks,
Brendon
(2020-02-28, 23:34)djgrind Wrote: [ -> ]Did everything (created 3 keys) and then tried method 1 and it didn't work, tried method 3 and I could do 2 step verify but as soon as that's done I get locked out. "YouTube error. Check log"
Tried a few times and out of ideas. Any help?
Managed to get it going.
Did method 1. Samething happened as previous after 2nd verify, I shut down lodi and manually went to the 1st json file and deleted. Restarted kodi and went back to YouTube, my api's are still there but it's asking to sign in again. I skipped the sign in this time and tested a video and it works. The end.
I guess this is a strange question; LibreElec 9.2 is still using Kodi 18.5 Python 2.7, the Youtube plugin 6.6.0 uses Python 3 all of a sudden.
Am I missing an easy way to make it function on LE 9.2? Or, does anybody know how to load Python 3 into 9.2?
It works on LE 9.8/Kodi 19 on my RPi3B, but not on my new RPi4 Milhouse is not supporting RPi4 yet
Hi
I got the error today settung up a new kodi on osmc.
Requesting device and user code failed: Code: |401| JSON: |{u'error_description': u'The OAuth client was deleted.', u'error': u'deleted_client'}|
2020-02-29 08:37:47.181 T:1443885792 ERROR: [plugin.video.youtube] LoginException: [401] deleted_client: The OAuth client was deleted.
tried it several time.
Google accepted the access.
what am I missing?
(2020-02-28, 23:38)brendonbell Wrote: [ -> ]Hi there,
Thanks,
Brendon
I am having this exact same issue on my Raspberry Pi 3B running latest Libreelec. I've set up my personal keys and signed in using method 1 which has worked, however when I launch the add-on it give the error 'Youtube Error - Checl the log for more information'. I can't find the log anywhere in Kodi files and deleting/reinstalling the add on doesn't make any difference.
Can anyone help?
yomgui, @
Dr.Kalvin
Please see the alpha2 version mentioned below.
brendonbell, @
[email protected]
That would suggest an issue with your Client ID and possibly Client Secret
donbrew
The add-on is python 2 and 3 compatible, python 2 support hasn't been removed.
If that doesn't help, I'll require a complete
debug log (wiki) with the issue.
I've updated post
#2 and the repositories with alpha2
[fixup] error after sign in for some users
(2020-02-29, 17:11)anxdpanic Wrote: [ -> ]@yomgui, @Dr.Kalvin
That did the trick for me !
Many thanks
(2020-02-29, 10:57)Dr.Kalvin Wrote: [ -> ] (2020-02-28, 23:38)brendonbell Wrote: [ -> ]Hi there,
Thanks,
Brendon
Can anyone help?
Do what I did (just a few posts up) and it'll work. Same issue I had
My Python problems seem to be LE related. I am getting different errors from different addons on different installations of LE. Weird, working on it.
I have YouTube working on RPi4 and RPi3B and LE9.8 now with the same credentials. I found that copying api_keys.json and then rebooting and then signing in did the job. Had to reboot not restart the addon.
@djgrind On LE go to LE configuration>system scroll down to the bottom to "Submit Log".
So with Personal API key videos are now limited to 360p?
Add-ons settings: Video quality 1080p Live / 720p HD
upd
not all videos but some are 360p, but I can watch them in the browser in 1080p
upd2
ok, found this issue
https://github.com/jdf76/plugin.video.yo...issues/737
Shomei
No, 1080p+ and HDR are working with or without(in the alpha) keys.
Enable
Settings - MPEG-DASH - Use MPEG-DASH
Enable
Settings - MPEG-DASH - Use for videos
Configure
Settings - MPEG-DASH - Video quality, etc.
Will need a complete
debug log (wiki) otherwise.
(2020-02-27, 19:03)anxdpanic Wrote: [ -> ]@Ojib
I'd need more information and a complete debug log (wiki), 'still don't play' doesn't give us much to go on.
If you don't use the add-on directly but only use it for trailers, or sharing from remotes etc, see post #2 for the alpha version. In the alpha version playback doesn't require API access, so anything using plugin://plugin.video.youtube/play/?video_id= urls should work without keys.
Just to let you know, I tried 6.7.0 Alpha 2 today and had to use Kore to share a YouTube video from the Firefox browser to Kodi. I usually use Yatse as my Kodi remote but that made it pop up the message about needing API keys.
When I hit the share button in the browser on the phone it shares 'https://www.youtube.com/watch?v=etc' or 'https://m.youtube.com/watch?v=etc' to either Kore or Yatse, but with Yatse something's different with the message by the time it gets to the YouTube add-on.
I also tried the Sky News, Nasa, and ESA Videos plug-ins and they work. The Kurzgesagt add-on unfortunately doesn't work.
As I'm trying to degooglefy as much as possible I'm reluctant to use API keys but I do understand what's happening with the previous set-up (a limited set of API keys shared between all Kodi users and subject to Google changing the usage limit and T&Cs). It would be nice if a couple of other basic things worked without API keys (e.g. search, channel listings) but I understand that would need a big re-design.
But anyway, that was my 6.7.0 Alpha 2 testing. The guy in charge of Yatse is pretty responsive so he may already be fixing this.
Anonnymouse
I might be able to figure out the issue with a complete
debug log (wiki) showing the Yatse playback attempt.
