I have right now install the alpha2 of 6.0.0-unofficial:
Thanks @
anxdpanic because now apparently all section it's works and apparently all video it's ok from all section but there's another addictional little trouble.
When i open the "My Subscription" (filter or not) the list of video it's correctly loaded but immediatelly after it, on my tv, appears a notification say again to see the log and report this error:
03:09:47.409 T:1294140160 NOTICE: [plugin.video.youtube] Running: YouTube (6.0.0~alpha2) on Krypton (Kodi-17.6) with Python 2.7.13
03:09:49.640 T:1294140160 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.NameError'>
Error Contents: global name 'xbmc' is not defined
File "/home/osmc/.kodi/addons/plugin.video.youtube/resources/lib/default.py", line 7, in <module>
runner.run(__provider__)
File "/home/osmc/.kodi/addons/plugin.video.youtube/resources/lib/youtube_plugin/kodion/runner.py", line 41, in run
__RUNNER__.run(provider, context)
File "/home/osmc/.kodi/addons/plugin.video.youtube/resources/lib/youtube_plugin/kodion/impl/xbmc/xbmc_runner.py", line 64, in run
xbmc.executebuiltin('Container.SetViewMode(%d)' % view_mode)
NameError: global name 'xbmc' is not defined
I hope always to do somethigs pleasant when i report this personal feedback..........
*EDIT*
After some test......... i have found the possibly cause.
From the preferences i have disabled the option for FORCE Setview. Previously i have set both value to 55 and all works. But if enable the forceviews i obtain this errors........
This is my settings:
<setting id="kodion.view.default" value="55" />
<setting id="kodion.view.episodes" value="55" />
<setting id="kodion.view.override" value="true" />
Whit view override disable no errors....... whit override activate i obtain the errors on log posted above..... it's a invalid id the cause ? I don't have idea
*EDIT 2*
From original post it's a new day right now... in italy it's around 10:30AM and i have some bad news.
Last night, beforse i go to sleep, i have report this feedback whit alpha2 unofficial 6.0.0.... apparently all works whitout any problems (whitout the ovveride feature no errors notification appears) but now i have some troubles.
I have turned on my Pi2 about 5 minutes ago and from addons all video i try to reproduce nothigs append..... i can see the "blue spin" on tv for about 1 or 2 sec and nothings. Simply back to the all video list....... this append in all section........ on log it's appears a message say somethigs about unplayable id 0 or similar (i can't post the parts of log right uppers right now.... try to do this later).
**EDIT 3**
This is the part of log when try to reproduce some video, and goes in errors, from "My Subscriction":
03:28:42.229 T:1310917376 NOTICE: [plugin.video.youtube] Running: YouTube (6.0.0~alpha2) on Krypton (Kodi-17.6) with Python 2.7.13
03:28:59.409 T:1925683712 NOTICE: Previous line repeats 1 times.
03:28:59.409 T:1925683712 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.youtube/play/?video_id=OpjJRUWq9Go]
03:29:37.201 T:1925683712 ERROR: Control 55 in window 10025 has been asked to focus, but it can't
03:29:40.360 T:1294140160 NOTICE: [plugin.video.youtube] Running: YouTube (6.0.0~alpha2) on Krypton (Kodi-17.6) with Python 2.7.13
03:32:07.291 T:1925683712 NOTICE: Previous line repeats 3 times.
03:32:07.291 T:1925683712 ERROR: GetDirectory - Error getting plugin://plugin.video.youtube/video/more/?refresh_container=0&logged_in=1&video_id=8SyWJIv3fc4
03:32:07.308 T:1925683712 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.youtube/video/more/?refresh_container=0&logged_in=1&video_id=8SyWJIv3fc4) failed
03:33:41.192 T:1310917376 NOTICE: [plugin.video.youtube] Running: YouTube (6.0.0~alpha2) on Krypton (Kodi-17.6) with Python 2.7.13
03:40:08.440 T:1925683712 NOTICE: Previous line repeats 8 times.
03:40:08.440 T:1925683712 ERROR: GetDirectory - Error getting plugin://plugin.video.youtube/video/more/?refresh_container=0&logged_in=1&video_id=xU6NzGFQQLg
03:40:08.456 T:1925683712 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.youtube/video/more/?refresh_container=0&logged_in=1&video_id=xU6NzGFQQLg) failed
03:40:18.250 T:1294140160 NOTICE: [plugin.video.youtube] Running: YouTube (6.0.0~alpha2) on Krypton (Kodi-17.6) with Python 2.7.13
03:40:21.819 T:1925683712 NOTICE: VideoPlayer: Opening:
03:40:21.819 T:1925683712 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
03:40:21.820 T:1310917376 NOTICE: Creating InputStream
03:40:21.835 T:1310917376 ERROR: Error on dvdnav_open
03:40:21.835 T:1310917376 ERROR: CVideoPlayer::OpenInputStream - error opening
03:40:21.835 T:1310917376 NOTICE: CVideoPlayer::OnExit()
03:40:21.846 T:1925683712 NOTICE: CVideoPlayer::CloseFile()
03:40:21.846 T:1925683712 NOTICE: VideoPlayer: waiting for threads to exit
03:40:21.846 T:1925683712 NOTICE: VideoPlayer: finished waiting
03:40:25.038 T:1294140160 NOTICE: [plugin.video.youtube] Running: YouTube (6.0.0~alpha2) on Krypton (Kodi-17.6) with Python 2.7.13
03:40:47.056 T:1925683712 NOTICE: Previous line repeats 1 times.
03:40:47.056 T:1925683712 NOTICE: VideoPlayer: Opening:
03:40:47.056 T:1925683712 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
03:40:47.057 T:1294140160 NOTICE: Creating InputStream
03:40:47.058 T:1294140160 ERROR: Error on dvdnav_open
03:40:47.058 T:1294140160 ERROR: CVideoPlayer::OpenInputStream - error opening
03:40:47.058 T:1294140160 NOTICE: CVideoPlayer::OnExit()
03:40:47.067 T:1925683712 NOTICE: CVideoPlayer::CloseFile()
03:40:47.067 T:1925683712 NOTICE: VideoPlayer: waiting for threads to exit
03:40:47.067 T:1925683712 NOTICE: VideoPlayer: finished waiting
03:40:47.068 T:1925683712 NOTICE: CVideoPlayer::CloseFile()
03:40:47.068 T:1925683712 NOTICE: VideoPlayer: waiting for threads to exit
03:40:47.068 T:1925683712 NOTICE: VideoPlayer: finished waiting
03:40:50.312 T:1310917376 NOTICE: [plugin.video.youtube] Running: YouTube (6.0.0~alpha2) on Krypton (Kodi-17.6) with Python 2.7.13
03:40:57.363 T:1925683712 NOTICE: Previous line repeats 1 times.
03:40:57.364 T:1925683712 NOTICE: VideoPlayer: Opening:
03:40:57.364 T:1925683712 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
03:40:57.365 T:1294140160 NOTICE: Creating InputStream
03:40:57.366 T:1294140160 ERROR: Error on dvdnav_open
03:40:57.367 T:1294140160 ERROR: CVideoPlayer::OpenInputStream - error opening
03:40:57.367 T:1294140160 NOTICE: CVideoPlayer::OnExit()
03:40:57.368 T:1925683712 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.youtube/play/?video_id=xU6NzGFQQLg]
03:40:57.369 T:1925683712 NOTICE: CVideoPlayer::CloseFile()
03:40:57.369 T:1925683712 NOTICE: VideoPlayer: waiting for threads to exit
03:40:57.369 T:1925683712 NOTICE: VideoPlayer: finished waiting
03:40:57.370 T:1925683712 NOTICE: CVideoPlayer::CloseFile()
03:40:57.370 T:1925683712 NOTICE: VideoPlayer: waiting for threads to exit
03:40:57.370 T:1925683712 NOTICE: VideoPlayer: finished waiting
03:41:00.628 T:1310917376 NOTICE: [plugin.video.youtube] Running: YouTube (6.0.0~alpha2) on Krypton (Kodi-17.6) with Python 2.7.13
03:41:09.673 T:1925683712 NOTICE: Previous line repeats 1 times.
03:41:09.674 T:1925683712 NOTICE: VideoPlayer: Opening:
03:41:09.674 T:1925683712 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
03:41:09.675 T:1628418816 NOTICE: Creating InputStream
03:41:09.676 T:1628418816 ERROR: Error on dvdnav_open
03:41:09.676 T:1628418816 ERROR: CVideoPlayer::OpenInputStream - error opening
03:41:09.676 T:1628418816 NOTICE: CVideoPlayer::OnExit()
03:41:09.677 T:1925683712 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.youtube/play/?video_id=x2Vv6oBlCWM]
03:41:09.691 T:1925683712 NOTICE: CVideoPlayer::CloseFile()
03:41:09.691 T:1925683712 NOTICE: VideoPlayer: waiting for threads to exit
03:41:09.691 T:1925683712 NOTICE: VideoPlayer: finished waiting
03:41:09.692 T:1925683712 NOTICE: CVideoPlayer::CloseFile()
03:41:09.692 T:1925683712 NOTICE: VideoPlayer: waiting for threads to exit
03:41:09.692 T:1925683712 NOTICE: VideoPlayer: finished waiting
03:41:12.947 T:1310917376 NOTICE: [plugin.video.youtube] Running: YouTube (6.0.0~alpha2) on Krypton (Kodi-17.6) with Python 2.7.13
03:41:22.285 T:1925683712 NOTICE: Previous line repeats 1 times.
03:41:22.285 T:1925683712 NOTICE: VideoPlayer: Opening:
03:41:22.285 T:1925683712 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
03:41:22.286 T:1628418816 NOTICE: Creating InputStream
03:41:22.287 T:1628418816 ERROR: Error on dvdnav_open
03:41:22.287 T:1628418816 ERROR: CVideoPlayer::OpenInputStream - error opening
03:41:22.287 T:1628418816 NOTICE: CVideoPlayer::OnExit()
03:41:22.288 T:1925683712 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.youtube/play/?video_id=xU6NzGFQQLg]
03:41:22.302 T:1925683712 NOTICE: CVideoPlayer::CloseFile()
03:41:22.302 T:1925683712 NOTICE: VideoPlayer: waiting for threads to exit
03:41:22.302 T:1925683712 NOTICE: VideoPlayer: finished waiting
03:41:22.303 T:1925683712 NOTICE: VideoPlayer: waiting for threads to exit
03:41:22.303 T:1925683712 NOTICE: VideoPlayer: finished waiting
03:41:25.475 T:1310917376 NOTICE: [plugin.video.youtube] Running: YouTube (6.0.0~alpha2) on Krypton (Kodi-17.6) with Python 2.7.13
03:41:26.972 T:1925683712 ERROR: GetDirectory - Error getting plugin://plugin.video.youtube/kodion/search/list/
03:41:26.989 T:1925683712 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.youtube/kodion/search/list/) failed
03:41:29.357 T:1294140160 NOTICE: [plugin.video.youtube] Running: YouTube (6.0.0~alpha2) on Krypton (Kodi-17.6) with Python 2.7.13
03:42:06.513 T:1925683712 ERROR: Control 55 in window 10025 has been asked to focus, but it can't
03:42:14.937 T:1310917376 NOTICE: [plugin.video.youtube] Running: YouTube (6.0.0~alpha2) on Krypton (Kodi-17.6) with Python 2.7.13
03:42:29.490 T:1925683712 NOTICE: Previous line repeats 1 times.
03:42:29.490 T:1925683712 NOTICE: VideoPlayer: Opening:
03:42:29.490 T:1925683712 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
03:42:29.491 T:1319305984 NOTICE: Creating InputStream
03:42:29.495 T:1319305984 ERROR: Error on dvdnav_open
03:42:29.495 T:1319305984 ERROR: CVideoPlayer::OpenInputStream - error opening
03:42:29.495 T:1319305984 NOTICE: CVideoPlayer::OnExit()
03:42:29.496 T:1925683712 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.youtube/play/?video_id=1wubsZDPH9s]
03:42:29.497 T:1925683712 NOTICE: CVideoPlayer::CloseFile()
03:42:29.497 T:1925683712 NOTICE: VideoPlayer: waiting for threads to exit
03:42:29.497 T:1925683712 NOTICE: VideoPlayer: finished waiting
03:42:29.498 T:1925683712 NOTICE: CVideoPlayer::CloseFile()
03:42:29.498 T:1925683712 NOTICE: VideoPlayer: waiting for threads to exit
03:42:29.498 T:1925683712 NOTICE: VideoPlayer: finished waiting
03:42:29.499 T:1059255040 ERROR: GetDirectory - Error getting /home/osmc/.kodi/temp/plugin.video.youtube/
03:42:29.499 T:1059255040 ERROR: GetDirectory - Error getting special://temp/plugin.video.youtube/
03:42:32.796 T:1294140160 NOTICE: [plugin.video.youtube] Running: YouTube (6.0.0~alpha2) on Krypton (Kodi-17.6) with Python 2.7.13
03:52:41.552 T:1925683712 NOTICE: stop all
03:52:41.553 T:1925683712 NOTICE: stop player
03:52:41.553 T:1925683712 NOTICE: ES: Stopping event server
It's a part of last night test.................. at 3:52AM it's goin to sleep after try to see some video
Ah.... i don't use DASH..... i don't have tryed whit dash enabled because after the recent changes it's not most clearly on my head how i need to set all preferences
