I've tried to employ my google-fu, but is it a YT/DASH quirk that the AAC bitrate drops for the DASH stream? Or am I doing something wrong? (Version 6.1.3 on a Pi2 with OSMC/KODI 17.6)
See
https://pasteboard.co/HCP0ina.png
Regards
/L
I'm getting an error on some videos ... many play but some do not but did last night ...
here is the log
https://paste.osmc.tv/sirosecaze
the error seems to start on the line that starts with this: 14:31:25.169 T:1503654656
tried rebooting - then logging out and back in ...
el Grincho The mpeg-dash quality shows the max supported streams, the higher quality streams are using a codec that inputstream.adaptive currently doesn't support.
xenophrenia It looks like youtube has changed something, need to look into it further
Ok, so the "legacy" non DASH 720p has AAC@192, but the DASH-stream only has AAC up to 128 and higher bitrate audio streams are using unsupported codecs? if I get it right?
Regards
/L
addendum
seems videos with music are the ones affected - I've been watching a lot of Marvel and GoT tribute videos and all of them with a song base are the ones that don't play - YouTube just launched a music service or a change to their music service - perhaps this is the cause of their change?
Looks like Youtube took a hammer to the mp3 ripping sites. Now no music videos play in the addon even the ones from years ago :-(
For. e.g.,
https://www.youtube.com/watch?v=vCEvCXuglqo
i have tried in 4 different devices all running kodi 17.6 at home all with the same results ,2 of them using api keys 2 without , any music files present an error all other videos play without problem . when i try to play the same music files through the official youtube/website app they play fine
(2018-08-24, 17:20)anxdpanic Wrote: [ -> ]@siliconhippy I double checked and did some testing;
IPTV Simple Client playlist:
#EXTM3U
#EXTINF:-1, YouTube Test
plugin://plugin.video.youtube/play/?video_id=yS2V6jQBXwk
On Kodi 17 it doesn't not work, on Kodi 18 it does work. There is nothing add-on wise that can be done to fix it for Kodi 17.
anxdpanic
Just in case, below is not a solution as 17.6 addon for above? I must go to Kodi 18 beta1?
(The install from zip in Addons keeps failing for m3u8-master.zip from GitHub.)
https://kodi.wiki/view/Add-on:M3u8
I have installed the latest beta from post 2 in the hope that I could get this plugin working, but still cannot play live streams from My Channel. It looks like they start, but rather than a video launching I just go back to the info window.
Debug log of me attempting to launch the live stream.
el Grincho
Correct, those qualities may differ slightly in some cases but still the same idea.
siliconhippy
That doesn't look like it would be of any help in resolving that issue.
wgstarks
HLS live streams in Kodi 17 aren't working, for working live streams you'll require;
- inputstream.adaptive >= 2.0.12 installed and enabled
- YouTube add-on Settings -> MPEG-DASH -> Use mpeg-dash and Use for live streams enabled.
If still an issue please provide a new log showing the issue.
xenophrenia, @
gujal, @
motlow , and everyone else:
the signature function not found issue is fixed in 6.1.4 and 6.2.0~alpha6
I've updated post
#2 with versions that fix the signature not found issue.
I have been having issues with YouTube off and on for forever. If it's not check log error it's something else. Also no 1080p videos. This made me do the following. I created a shortcut on my desktop. Filled in the link to chrome in Windows. After the link I pasted the url to YouTube tv between " ". So that's
https://YouTube.com/tv# and using advanced launcher made a favourite to the shortcut. I used the shortcut for my skin and now I have full YouTube TV with phone control and HD from within Kodi. No more drama in my life..
(2018-09-08, 17:00)anxdpanic Wrote: [ -> ]@xenophrenia, @gujal, @motlow , and everyone else:
I've updated post #2 with versions that fix the signature not found issue.
THANK YOU ... you have no idea how happy this makes me to be able to watch this properly again ;-)
https://www.youtube.com/watch?v=o6OVYkFLQlQ
(2018-09-08, 17:00)anxdpanic Wrote: [ -> ]@wgstarks
Worked great. Had a little trouble installing inputstream.adaptive. Looks like latest versions aren't compatible, but once I found it in the official repo no problems getting live stream working. THANKS.
(2018-09-08, 23:12)wgstarks Wrote: [ -> ] (2018-09-08, 17:00)anxdpanic Wrote: [ -> ]@wgstarks
Looks like I posted too soon. Live stream plays great for about 60 seconds or so and then stops. View returns to info window. I may have something misconfigured in inputstream.adaptive settings.
New debug log
