I'm on kodi 18 on a raspberry 3 and until I updated to kodi 18 youtube was working perfectly.
Now when I add the Personal keys on 6.4.0 of this plugin like this:
<!-- personal api key -->
<category label="30200">
<setting id="youtube.api.enable" type="bool" label="30204" value="true"/>
<setting id="youtube.api.key" type="text" label="30201" value="xxxxxxxxxxxxxxxxxxxxxxxxx" visible="eq(-1,true)"/>
<setting id="youtube.api.id" type="text" label="30202" value="xxxxxxxxxxxxxxxxxxxxxxxxxxxx" visible="eq(-2,true)"/>
<setting id="youtube.api.secret" type="text" label="30203" value="xxxxxxxxxxxxxxxxxxxxxxxxxx" visible="eq(-3,true)"/>
<setting id="youtube.api.key.switch" type="enum" label="30205" values="0|1|2|3|4|5" visible="eq(-4,false)" default="1"/>
<setting id="youtube.allow.dev.keys" type="bool" label="30608" default="true"/>
<setting id="youtube.api.config.address" type="lsep" label="30633" visible="eq(1,true)"/>
<setting id="youtube.api.config.page" type="bool" label="30632" default="false"/>
</category>
(I changed default to value in the variable name)
I get:
2019-04-04 09:55:44.835 T:1498407664 ERROR: [plugin.video.youtube] Requesting device and user code failed: Code: |401| JSON: |{u'error_description': u
'The OAuth client was not found.', u'error': u'invalid_client'}|
I tried using client ID with and without the apps.googleusercontent.com, neither work.
Is there something wrong with the setup wizard maybe?
How can I search more thoroughly in the logs?
(2019-04-03, 18:19)Damnster Wrote: [ -> ] (2019-04-03, 17:41)anxdpanic Wrote: [ -> ]@Damnster
Your login information has been corrupted somehow
Execute 'Settings - Maintenance - Delete access_manager.json'
or
Manually delete userdata (wiki)\addon_data\plugin.video.youtube\access_manager.json
Thanks, it worked.
Something changed on YT side.
I also had to relog with my both clients.
One runs stable, the other alpha/beta Plugin.
(2019-04-04, 10:00)stokks Wrote: [ -> ]--> SNIP <--
double check your keys. also make sure it didn't get disabled by accident. Google Console does that sometimes.
Jeff
(2019-04-04, 17:50)jdf76 Wrote: [ -> ] (2019-04-04, 10:00)stokks Wrote: [ -> ]--> SNIP <--
Jeff
I think I checked it two or three times, and I'm sure they are correct
But no result.
About the Google console, i see that the API usage is detected, but still I get the same error...
Is there anything else I can do?
Hey guys, there are some seemingly random videos that wont play using the add-on. Here is one that I cant get to work. It seems to start to play and retrieves the title but just quits out.
Here is the video link
https://www.youtube.com/watch?v=Jn-3KuuVj-o
Here is the relevant part of my debug log
pelubufesa.kodi (paste)
(2019-04-06, 03:59)Pigeon14 Wrote: [ -> ]Hey guys, there are some seemingly random videos that wont play using the add-on. Here is one that I cant get to work. It seems to start to play and retrieves the title but just quits out.
Here is the video link https://www.youtube.com/watch?v=Jn-3KuuVj-o
Here is the relevant part of my debug log pelubufesa.kodi (paste)
That video doesn't work for me either
(2019-04-05, 12:01)stokks Wrote: [ -> ]Hi,
But no result.
at this point i would send a
debug log (wiki) to see whats up with the oauth id. Other thing you could do is try recreating the id.
Jeff
Can you do a
debug log (wiki) for us so we can see the error you are getting.
jeff
(2019-04-07, 13:53)jdf76 Wrote: [ -> ] (2019-04-06, 03:59)Pigeon14 Wrote: [ -> ]Hey guys, there are some seemingly random videos that wont play using the add-on. Here is one that I cant get to work. It seems to start to play and retrieves the title but just quits out.
Can you do a debug log (wiki) for us so we can see the error you are getting.
jeff
I linked to the log. The relevant part starts around line 95.
(2019-04-03, 17:41)anxdpanic Wrote: [ -> ]@saxonthebeach
Enable and configure MPEG-DASH (in the YouTube add-on settings) and InputStream Adaptive, if that doesn't resolve the issue provide a complete debug log (wiki)
In settings -> MPEG-DASH "Use MPEG-DASH" is greyed out. It says "Proxy is required for mpeg-dash vods (see HTTP Server). I'm not sure what I need to have in my HTTP Server settings.
Pigeon14
You only provided a snippet of the
debug log (wiki), that video also works fine here.
saxonthebeach
You don't need to change your HTTP Server settings, just need to enable Use MPEG-DASH and Use for videos.
Use MPEG-DASH is greyed out because InputStream Adaptive is not installed or enabled, how to do that will depend on your OS. Searching this thread you may find that information as well.
(2019-04-08, 02:52)anxdpanic Wrote: [ -> ]@Pigeon14
You only provided a snippet of the debug log (wiki), that video also works fine here.
@saxonthebeach
Here is a full log of the video not working. 95% of other videos work but this one does not. I've had others refuse to work in the past as well, but have never kept a list.
cisegunuku.kodi (paste)
