Full Version: Kodi 18.6 on Sony Android TV with Skin Amber - change menu "Pictures"
Hi Community!
I'm almost desperate ...
My Kodi 18.6 on Sony Android TV works perfectly and I am fully satisfied.
Only one little thing really annoys me. I try to describe the whole thing.
When I open the "Camcorder" folder (ie with video files) from the main menu, the following image looks like the attachment "Camcorder.jpg"
However, when I open the "Pictures" folder (ie picture content with JPGs) from the main menu, the following picture looks like the attachment "Pictures.jpg"
As you can see in the picture, I would like to have the middle, red bordered area away. Here you can display EXIF ​​information, etc.
I don't want that.
For that, I would rather have the folder structure as shown in "Camcorder" nice and big.
Can someone please help me please?
What do I have to change or re-program where?
I'm really grateful for any help!
Best regards
Nicole
Access denied. You are not authorized to view this page. Image
use i imgur next to face to upload image
Link to kodinerds.net! -  The pictures are the same but the problem described in german! :-)
Thank you once again for your help in advance.
Best regards
Nicole
Solved! Had to update Amber with repo!
(2020-04-08, 17:08)nicole.sabene Wrote: [ -> ]Solved! Had to update Amber with repo!
@nicole.sabene , I am glad you were able to solve it.  In the current version of Amber that is on GitHub (https://github.com/bartolomesoriano/skin.amber), you can also disable the info panel on a per media basis, meaning that you can have it disabled for Pictures, but leave it enabled for Movies if you like.
Regards,
Bart
