2020-05-09, 15:46
hello, i cant get dolby vision to work in my shield, installed the suggested IA version. if i enable hdr, streams run in 4k and hdr, but if i enable dolby vision, the stream starts with the audio player and only audio
(2020-05-08, 20:05)matthuisman Wrote: [ -> ](2020-05-08, 19:51)Wagg Wrote: [ -> ]On android its sort of tricky to update built-in addons.(2020-05-08, 11:56)matthuisman Wrote: [ -> ]See here:
https://forum.kodi.tv/showthread.php?tid...pid2947397
Still not working for me on my Shield+Leia. Even after updating IA all I am getting is sound with no picture.
Edit- 1080p working fine on my Shield, just no 4k content, all I get is spinning icon.
I've put a little how-to here: https://forum.kodi.tv/showthread.php?pid...pid2947397
0.2.7 Just Pushed
This has a workaround to allow the full-res worldwide (not just USA)
Again, requires L1 Android Device.
@popeye2468
Latest shared code should fix the no-sort options as well.
I changed the default folder content from episodes to videos which seems to have fixed it.
Even tested in that skin
PS:
Who rated thread 4 star? That's just mean!
0.2.7 Just Pushed
@popeye2468
PS:
(2020-05-07, 00:40)matthuisman Wrote: [ -> ]Here are some Leia IA builds with latest features back-ported to try:
https://jenkins.kodi.tv/blue/organizatio.../artifacts
Subs should work
Green screen on Android should be fixed
Dolby Vision should work
To install on Android Kodi Leia
1) install downloaded zip
2) restart kodi
3) uninstall inpustream adaptive
4) restart kodi
5) install downloaded zip
6) restart kodi
7) test
(2020-05-10, 04:02)matthuisman Wrote: [ -> ]Use stable Leia from playstore. I've confirmed that working on my shield.
I think newer kodi you can't replace IA correctly
(2020-05-09, 22:07)matthuisman Wrote: [ -> ]@Johnny1982fd
The IA build from here https://forum.kodi.tv/showthread.php?tid...pid2947397 should fix your DD+ 2.0 audio issue
(2020-05-10, 15:11)MattJ2000 Wrote: [ -> ]Me too...
Nvidia Shield TV Pro 2019
Nightly Kodi 18.6/7
Disney+ Version 0.2.7
4K Dolby Version = now OK
4K HDR 10 = OK
BUT
now Netflix & Prime Video addon can only playback 1920 x 1080
(2020-05-10, 15:29)m2k1980 Wrote: [ -> ]Prime addon never worked for 4k.(2020-05-10, 15:11)MattJ2000 Wrote: [ -> ]Me too...
Nightly Kodi 18.6/7
4K HDR 10 = OK
BUT
for me netflix is still running with dv on 4k. did you reconfigure IA after reinstalling it? min bantdwith, ignore hdcp status and ignore resolution?
(2020-05-10, 15:29)m2k1980 Wrote: [ -> ](2020-05-10, 15:11)MattJ2000 Wrote: [ -> ]Me too...
Nightly Kodi 18.6/7
4K HDR 10 = OK
BUT
