matthuisman
UPDATE: After update 1.1.4 I have gotten 1080p output from Fire TV.
Noted: green screen of death is still present.
Hi @
matthuisman
2 questions:
1.) Is that a known bug, that Dolby Digital 2.0 doesnt work with passthrough?
2.) Are you planning to implement "My Watchlist" ?
#1 - No idea - Maybe kodi issue??
#2 - yes
(2020-04-17, 14:38)matthuisman Wrote: [ -> ]#1 - No idea - Maybe kodi issue??
#2 - yes
1.) No, Netflix addon is working. For example go to Simpsons Season 1 Epiosode 1. Two audiostream Dolby Surround is working, Dolby Digital 2.0 is not working)
2.) Nice
(2020-04-17, 17:55)27hectormanuel Wrote: [ -> ] (2020-04-16, 23:46)matthuisman Wrote: [ -> ]
pretty sure they don't have 1080p.
Should either be 720 or 4k.
For android, we need this branch merged
https://github.com/peak3d/inputstream.ad...ree/hlskid
It will be merged into MAtrix hopefully soon.
Have also requested back-port to Leia.
1080p?
odd. no idea how you got that.
What are your settings under Playback in the add-on?
L1 Widevine Enabled? H265 Enabled?
If you have it set to ASK for quality - is 1080 listed in the qualities?
(2020-04-17, 20:32)matthuisman Wrote: [ -> ] (2020-04-17, 17:55)27hectormanuel Wrote: [ -> ] (2020-04-16, 23:46)matthuisman Wrote: [ -> ]
1080p?
I got,
Playback Quality: Best
WINEVINE L1 - ENABLED
H265 - ENABLED
HDR10 - ENABALED
*omg, I HAVE 1080P ON ASK...!"
14.MBITS 1920X1080 23.98 FPS.
This began happening after I installed ver. 1.1.4 on my Fire Stick 4K. Although, no actual playback possible.... green screen of death only.
I wonder, are fire sticks are the only android devices w/ FHD?
Hi@
matthuisman
I have installed OSMC running Kodi 18.6 on a RPi 2 and installed Dysney+ according to your procedure (nice tuto !!) :
However, the add-on inputstream adaptive is still at Ver 2.4.3, and no update at 2.4.4 available....
I am not an expert, my question is may be stupid, but need I wait for an update or can I do something to force this update?
Thank you for your help!
Kind regards,
Philippe
(2020-04-17, 23:10)A600 Wrote: [ -> ] (2020-04-17, 22:20)27hectormanuel Wrote: [ -> ]BTW, I'm using this version/fork of Kodi: https://github.com/Montellese/xbmc
It should work as long as you install the IA addon I posted above.
It will fix the green screen of death? I'll try it.
