Could you guys help troubleshoot for me. I can play the red button streams but everything else throws out an error. See below:
23:40:48 T:139977443088384 NOTICE: DVDPlayer: Opening:
http://ve-hds-uk-live.bbcfmt.vo.llnwd.ne...04000.m3u8
23:40:48 T:139977443088384 WARNING: CDVDMessageQueue(player):
ut MSGQ_NOT_INITIALIZED
23:40:48 T:139974301177600 NOTICE: Creating InputStream
23:40:49 T:139974301177600 NOTICE: Creating Demuxer
23:40:53 T:139974301177600 NOTICE: Opening stream: 1 source: 256
23:40:53 T:139974301177600 NOTICE: Creating video codec with codec id: 28
23:40:53 T:139974301177600 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
23:40:53 T:139974301177600 NOTICE: Creating video thread
23:40:53 T:139974301177600 NOTICE: Opening stream: 0 source: 256
23:40:53 T:139974301177600 NOTICE: Finding audio codec for: 86018
23:40:53 T:139974326351616 NOTICE: running thread: video_thread
23:40:53 T:139974301177600 NOTICE: Creating audio thread
23:40:53 T:139975685281536 NOTICE: running thread: CDVDPlayerAudio:
rocess()
23:59:36 T:139977443088384 DEBUG: StartScript - calling plugin iPlayer WWW('plugin://plugin.video.iplayerwww/','50','?url=http%3A%2F%2Fwww.bbc.co.uk%2Fiplayer%2Fepisode%2Fb0795nqy&mode=202&name=Bake+Off+Creme+de+la+Creme+-+Episode+5&iconimage=http%3A%2F%2Fichef.bbci.co.uk%2Fimages%2Fic%2F406x228%2Fp03rn0w3.jpg&description=The+teams+transform+chocolate+cheesecake+into+stunning+showpiece+displays.&subtitles_url=&logged_in=False')
23:59:36 T:139977443088384 DEBUG: WaitOnScriptResult - waiting on the iPlayer WWW (id=81) plugin...
23:59:36 T:139974160566016 DEBUG: Thread LanguageInvoker start, auto delete: false
23:59:36 T:139974160566016 INFO: initializing python engine.
23:59:36 T:139974160566016 DEBUG: CPythonInvoker(81, /home/kodi/.kodi/addons/plugin.video.iplayerwww/default.py): start processing
23:59:37 T:139974160566016 DEBUG: -->Python Interpreter Initialized<--
23:59:37 T:139974160566016 DEBUG: CPythonInvoker(81, /home/kodi/.kodi/addons/plugin.video.iplayerwww/default.py): the source file to load is "/home/kodi/.kodi/addons/plugin.video.iplayerwww/default.py"
23:59:37 T:139974160566016 DEBUG: CPythonInvoker(81, /home/kodi/.kodi/addons/plugin.video.iplayerwww/default.py): setting the Python path to /home/kodi/.kodi/addons/plugin.video.iplayerwww:/home/kodi/.kodi/addons/script.module.requests/lib:/usr/lib/python2.7:/usr/lib/python2.7/plat-x86_64-linux-gnu:/usr/lib/python2.7/lib-tk:/usr/lib/python2.7/lib-old:/usr/lib/python2.7/lib-dynload:/usr/local/lib/python2.7/dist-packages:/usr/lib/python2.7/dist-packages:/usr/lib/python2.7/dist-packages/PILcompat:/usr/lib/python2.7/dist-packages/gtk-2.0
23:59:37 T:139974160566016 DEBUG: CPythonInvoker(81, /home/kodi/.kodi/addons/plugin.video.iplayerwww/default.py): entering source directory /home/kodi/.kodi/addons/plugin.video.iplayerwww
23:59:37 T:139974160566016 DEBUG: CPythonInvoker(81, /home/kodi/.kodi/addons/plugin.video.iplayerwww/default.py): instantiating addon using automatically obtained id of "plugin.video.iplayerwww" dependent on version 2.19.0 of the xbmc.python api
23:59:38 T:139977443088384 DEBUG: DialogProgress::Open called
23:59:38 T:139977443088384 DEBUG: ------ Window Init (DialogProgress.xml) ------
23:59:42 T:139974160566016 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.IndexError'>
Error Contents: list index out of range
File "/home/kodi/.kodi/addons/plugin.video.iplayerwww/default.py", line 204, in <module>
Video.AddAvailableStreamItem(name, url, iconimage, description)
File "/home/kodi/.kodi/addons/plugin.video.iplayerwww/resources/lib/ipwww_video.py", line 756, in AddAvailableStreamItem
PlayStream(name, match[0][2], iconimage, description, subtitles_url)
IndexError: list index out of range
23:59:42 T:139977443088384 DEBUG: ------ Window Init (DialogKaiToast.xml) ------
23:59:42 T:139974160566016 INFO: Python script stopped
I can upload full log to pastebin if needed. I'm running the following:
Starting Kodi (16.0 Git:a5f3a99). Platform: Linux x86 64-bit
23:33:23 T:139977443088384 NOTICE: Using Release Kodi x64 build
23:33:23 T:139977443088384 NOTICE: Kodi compiled Apr 23 2016 by GCC 4.8.4 for Linux x86 64-bit version 3.13.11 (199947)
23:33:23 T:139977443088384 NOTICE: Running on Ubuntu 14.04.4 LTS, kernel: Linux x86 64-bit version 3.13.0-74-generic
23:33:23 T:139977443088384 NOTICE: FFmpeg statically linked, version: 2.8.6-kodi-2.8.6-Jarvis-16.0
23:33:23 T:139977443088384 NOTICE: Host CPU: Intel® Core i3 CPU 530 @ 2.93GHz, 4 cores available
