2017-04-27, 13:00
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190
2017-04-27, 13:00
2017-04-27, 14:02
(2017-04-27, 13:00)CaptainT Wrote: [ -> ](2017-04-27, 12:52)castalla Wrote: [ -> ](2017-04-27, 12:05)CaptainT Wrote: [ -> ]I am afraid this might be the ominous TLS bug primaeval was referring to.Thanks. You're correct - no effect. Same error messages. Grrrr!
I will try to address this tonight.
Many thanks!
2017-04-28, 00:48
(2017-04-27, 14:02)castalla Wrote: [ -> ](2017-04-27, 13:00)CaptainT Wrote: [ -> ]I will try to address this tonight.
Many thanks!
Please try to install the alpha version from here, go to settings, choose to ignore HTTPS streams and report if this fixes the problem. If it does, I will add it to 2.5.13 as soon as possible.
2017-04-28, 01:09
(2017-04-28, 00:48)CaptainT Wrote: [ -> ](2017-04-27, 14:02)castalla Wrote: [ -> ](2017-04-27, 13:00)CaptainT Wrote: [ -> ]I will try to address this tonight.
Many thanks!
Thanks. This alpha fixes the problem! I've tried it on a variety of streams.
Excellent work!
2017-04-28, 01:36
Hey all, long time listener, first time caller...
I have what may be a unique issue. So far, and for the past few months, every other video add-on works with very few or no problems. However, the iPlayer seems to be the exception.
All problems are with the catch-up service.
There are times when I can start any program, from any list, and have no issue watching the whole thing. But, more often than not, I will have an issue so severe, I have to stop what I am watching and then restart it. This does not always work. When it does not, I have to go to the BBC website to watch.
The main issue is when the stream buffers. I have corrected the buffering for the most part, but will still get one or two during an hour long show. When the stream buffers and then starts again, within a few seconds to a minute or so, the video will begin to stutter, the audio will too, and sometimes the audio will continue while the video freezes. I have also noticed it happening without the buffer ring of death in the last week or so. It becomes completely unwatchable.
As I mentioned, this only happens with this add-on (iPlayer WWW).
Has anyone else experienced this? Is there a solution?
I am running Ubuntu Studio 14.04, have a 6 core AMD processor, NVIDIA GT 720 2GB video card, and 8 GB ram. The video card is using the proprietary drivers (375, but there is an option for 381). I have tweaked everything I can think of internally on Kodi, and have made sure the OS/system is doing all the video/audio work (as some of the Kodi defaults made some things just not work).
I leave this in your capable hands. Any other info needed, just let me know. Thanks.
2017-04-28, 01:54
(2017-04-28, 01:36)sydbat Wrote: [ -> ]The main issue is when the stream buffers. I have corrected the buffering for the most part, but will still get one or two during an hour long show. When the stream buffers and then starts again, within a few seconds to a minute or so, the video will begin to stutter, the audio will too, and sometimes the audio will continue while the video freezes. I have also noticed it happening without the buffer ring of death in the last week or so. It becomes completely unwatchable.
I have seen this behaviour from time to time and each time it has happened to me, I have been able to determine that the problem is not the plugin nor Kodi buffer settings (BTW I have *always* found that changing the Kodi buffering defaults results in poorer performance). Rather, by inspecting the inbound streams using a 'network sniffer', I have seen the the problem is the content provider (the provider is simply not delivering a reliable stream and you can see this by looking at the network flows). Note that the Beeb does not actually provide the content -- it is provided by Akamai or Limelight (last time I checked). Both of these services are geo-dependent and the server providing content is selected based on your location. In my experience, I had better luck with Limelight than Akamai, so you might try a switch from one to the other and see if you get any improvement.
2017-04-28, 02:11
(2017-04-28, 01:54)oattes Wrote: [ -> ](2017-04-28, 01:36)sydbat Wrote: [ -> ]The main issue is when the stream buffers. I have corrected the buffering for the most part, but will still get one or two during an hour long show. When the stream buffers and then starts again, within a few seconds to a minute or so, the video will begin to stutter, the audio will too, and sometimes the audio will continue while the video freezes. I have also noticed it happening without the buffer ring of death in the last week or so. It becomes completely unwatchable.
Ahhh. I hadn't thought of changing providers. I figured it has to do with the stream itself, not the plugin, but one never knows. I'll give it a try and post back results. Thanks.
I just noticed one provider called Bidi. Any experience with that one?
2017-04-28, 04:21
(2017-04-28, 01:09)castalla Wrote: [ -> ](2017-04-28, 00:48)CaptainT Wrote: [ -> ](2017-04-27, 14:02)castalla Wrote: [ -> ]Many thanks!
Excellent work!
Working here too after manual upgrade to alpha version 2.5.13, thanks for your hard work and dedication.
2017-04-28, 05:10
(2017-04-27, 07:46)CaptainT Wrote: [ -> ](2017-04-27, 02:11)lee3lions Wrote: [ -> ]Using v 3.0.5. After selecting tv show, app attempts connection and then closes Kodi and returns to FireTV home screen.This sounds more like an issue with Kodi than with the addon. FireTV is running an Android derivative, right? There have been reports of crashes when using DASH on Android. Please change the stream protocol in settings from DASH to HLS and try again.
Kodi is Krypton version.
I changed to HLS. Now I get the following error message:
HTTPSConnectionPool (host='vod-hls-uk-live-akamaized.net',port=433):
Max retries exceeded with url:
/usp/auth/vod/piff_abr_full_hd/fd0261-b08nt9yr/vf_b08nt9yr_8a9
(Caused by
NewConnectionError ('requests.packages.urllib3.connection.Veri
Object at 0xad49d868:failed to establish a new connection:
(Ermo 111) connection refused'))
I was initially using v 2.5.6 with no problem except the lack of "Categories" This problem started when I enabled
,"inputstream adaptive - peak3d-1.0.8" and upgraded to v 3.0.5.
I uninstalled Kodi Krypton completely, reinstalled Jarvis and tried 2.5.12 and that version wouldn't work either. I am now back on Krypton, with v 3.0.5 getting the above error.
2017-04-28, 08:26
(2017-04-28, 05:10)lee3lions Wrote: [ -> ]I changed to HLS. Now I get the following error message:
(Caused by
This error looks like you were geoblocked. Are you sure you are in the UK and do not use any VPN?
2017-04-28, 11:00
(2017-04-28, 08:26)CaptainT Wrote: [ -> ](2017-04-28, 05:10)lee3lions Wrote: [ -> ]I changed to HLS. Now I get the following error message:
(Caused by
I'm pretty sure that is the https warning error on Jarvis from my experience.
2017-04-28, 13:22
(Caused by
Forget VPN - I have found it seldom works - switch to a Smart DNS - never fails and doesn't throttle speeds down
2017-04-28, 15:28
Many thanks!
I'm still getting the same error as reported above. Any idea when 2.5.13 will be available for us to download please?
2017-04-28, 15:32
(2017-04-28, 15:28)padget624 Wrote: [ -> ]I'm still getting the same error as reported above. Any idea when 2.5.13 will be available for us to download please?Which version are you on at the moment? 2.5.12 or 2.5.13~alpha?
It may take a couple of days till 2.5.13. primaeval has brought up an interesting alternative to address this issue, but I would like to test that myself and most likely won't get to that during the weekend.
2017-04-28, 15:35
(2017-04-28, 15:32)CaptainT Wrote: [ -> ](2017-04-28, 15:28)padget624 Wrote: [ -> ]Which version are you on at the moment? 2.5.12 or 2.5.12~alpha?(2017-04-28, 00:48)CaptainT Wrote: [ -> ]Please try to install the alpha version from here, go to settings, choose to ignore HTTPS streams and report if this fixes the problem. If it does, I will add it to 2.5.13 as soon as possible.
The alpha version works. It doesn't find all the higher resolution streams for some programs but it definitely works on Android 4.4.2 Kodi 16.1 Jarvis on a crappy old MXQ box. I'd use that for the time being if I were you.
I had to choose the Akamai streams but it might just be my setup.
