2020-04-10, 15:48
When I add the following file (with "automatic renaming" on):
It will be added and renamed as a Dolby Digital file (cause that's the default audio track of the file, I think?).
How can I change it to the second audiotrack (Atmos) after adding it to TMM? Or should I do something before adding it to TMM?
How I do it now is:
- Add the file in TMM.
- Rename the filename manually with Atmos in the name.
- Kodi shows Atmos, TMM still Dolby Digital.
My goal is to have it in TMM with the Atmos track and renamed accordingly, so Kodi will also display the correct/preffered Atmos audiotrack.
Without having to change it manually, is this possible or is my method wrong?
Quote:General
Unique ID :
Complete name :
Format : Matroska
Format version : Version 4
File size : 17.9 GiB
Duration : 50 min 48 s
Overall bit rate mode : Variable
Overall bit rate : 50.4 Mb/s
Encoded date : UTC 2020-04-08 10:33:57
Writing application : mkvmerge v45.0.0 ('Heaven in Pennies') 64-bit
Writing library : libebml v1.3.10 + libmatroska v1.5.2
Video
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main [email protected]@high
HDR format : SMPTE ST 2086, HDR10 compatible
Codec ID : V_MPEGH/ISO/HEVC
Bit rate : 44.8 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 25.000 FPS
Original frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0 (Type 2)
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.216
Stream size : 15.9 GiB (89%)
Title : MPEG-H HEVC Video / 44826 kbps / 2160p / 25 fps / 16:9 / Main 10 Profile 5.1 High / HDR / BT.2020
Language : English
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Matrix coefficients : BT.2020 non-constant
Mastering display color primaries : Display P3
Mastering display luminance : min: 0.0050 cd/m2, max: 1000 cd/m2
Maximum Content Light Level : 1019 cd/m2
Maximum Frame-Average Light Level : 278 cd/m2
Audio #1
Format : AC-3
Format/Info : Audio Coding 3
Commercial name : Dolby Digital
Codec ID : A_AC3
Duration : 50 min 47 s
Bit rate mode : Constant
Bit rate : 640 kb/s
Channel(s) : 6 channels
Channel layout : L R C LFE Ls Rs
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Compression mode : Lossy
Delay relative to video : 24 ms
Stream size : 232 MiB (1%)
Title : Compatibility Track / Dolby Digital Audio / 5.1-EX / 48 kHz / 640 kbps
Language : English
Service kind : Complete Main
Default : Yes
Forced : No
Audio #2
Format : MLP FBA 16-ch
Format/Info : Meridian Lossless Packing FBA with 16-channel presentation
Commercial name : Dolby TrueHD with Dolby Atmos
Codec ID : A_TRUEHD
Duration : 50 min 46 s
Bit rate mode : Variable
Bit rate : 4 855 kb/s
Maximum bit rate : 7 110 kb/s
Channel(s) : 8 channels
Channel layout : L R C LFE Ls Rs Lb Rb
Frame rate : 1 200.000 FPS (40 SPF)
Compression mode : Lossless
Delay relative to video : 1 ms
Stream size : 1.72 GiB (10%)
Title : Dolby TrueHD/Atmos Audio / 7.1 / 48 kHz / 4855 kbps / 24-bit
Language : English
Default : No
Forced : No
Number of dynamic objects : 11
Bed channel count : 1 channel
Bed channel configuration : LFE
How I do it now is:
