Full Version: script.module.xbmcswift2
Not sure if anyone is maintaining this any more but since V19 has removed ListItem.iconImage and ListItem.thumbnailImage these need removing from lib/listitem.py.  I'd submit a PR with the required changes but I'm unsure where to submit it to.
@enen92 You seem to be the the best person to ask so have you any advice or can you fix this yourself ?
The args were kept in the lib for compatibility reasons but internally the module uses setArt: https://github.com/XBMC-Addons/script.mo...tem.py#L44
It was forked to script.module.kodiswift at https://github.com/afrase/kodiswift, but it seems abandoned there too.
