Hi
Newbie here, so please be gentle. ;-)
I've tried this function on some test files and it seems to work well, except that it leaves the subtitle files in the top level folder, when I kind of expected it to copy all associated files (with the same filename) into the newly created subfolder.
Or does it not work this way? I couldn't find any docs on the function.
Can you post a screenshot how the video and subtitle files are named befor moving? The subtitles has to start with the same file name like the movie file, e.g.
D:\Avatar.bluray.mkv
D:\Avatar.bluray-english.srt
D:\Avatar.bluray.german.forced.srt
D:\Avatar.bluray spanish.srt
D:\Die.Hard.mkv
D:\Die.Hard-english.srt
D:\Die.Hard.german.forced.srt
D:\Die.Hard spanish.srt
otherwise it's ipossible to recognize that a subtitle or any other file belongs to a video file. Also this function is only usefull if you store all files in a single and not in separate folders.
Before:
PS V:\films 4> dir
Directory: V:\films 4
Mode LastWriteTime Length Name
-a---- 27/12/2004 15:13 745622016 A Bout de Souffle (1960) [Breathless] by Jean-Luc Godard.avi
-a---- 21/12/2004 17:32 66485 A Bout de Souffle (1960) [Breathless] by Jean-Luc Godard.srt
After "Sort files into folder":
PS V:\films 4> dir -R
d----- 14/04/2020 22:53 A Bout de Souffle (1960) [Breathless] by Jean-Luc Godard
Directory: V:\films 4\A Bout de Souffle (1960) [Breathless] by Jean-Luc Godard
Ok, that's looks like a bug, I've to check that.
OK tx for looking.
I've also noticed that it ignores .rec and .mds files (though I guess the latter is superfluous).
So, the problem is that i've changed it from "file has to begin with same like file name" to "only move file names that already has a proper name scheme that fits". The reason was that in some cases I cannot distinguish which movie a file belongs to. If you've this case
D:\Movies\Die Hard.mkv
D:\Movies\Die Hard with a Vengeance.mkv
D:\Movies\Die Hard with a Vengeance.srt
The file "D:\Movies\Die Hard with a Vengeance.srt" also starts with "D:\Movies\Die Hard" and whould be moved into the wrong folder.
I think i need a better way, maybe start with the longest file names to prevent this issue and move it away before a shorter movie has been handled. I'll do some tests tomorrow to fix that. It's midnight for me and I have to work tomorrow.
Ok - I've no idea what the name scheme is, I just naively expected it to copy files into the same folder that obviously belonged together. I suppose if there is a question over that then one could make the operation interactive and prompt the user? Or if interactive operation is not desired then one could have an option ...
But of course I realise that my knowledge of all this is rather low! Thanks again for looking.
