Full Version: M3U inputstreamaddon and inputstreamclass to be deprecated in favour of inputstream
All,
For any PVR addons using M3U files the use of both inputstreamaddon and inputstreamclass will be deprecated in favour of inputstream. The reason for this is that neither refer to all inputstreams and having multiple supported adds complexity.
For example these would have been valid before the deprecation:
#KODIPROP:inputstreamaddon=inputstream.ffmpegdirect
#KODIPROP:inputstream.ffmpegdirect.mime_type=video/mp2t
#KODIPROP:inputstream.ffmpegdirect.program_number=2154
#KODIPROP:inputstream.ffmpegdirect.is_realtime_stream=true
#EXTINF:-1,MyChannel
http://127.0.0.1:3002/mystream.ts
or
#KODIPROP:inputstreamclass=inputstream.ffmpegdirect
Following the deprecation both would change to:
#KODIPROP:inputstream=inputstream.ffmpegdirect
As of today the next nightly builds will support inputstream in Kodi v19 Matrix. The plan being to remove the old values from v19 at the end of May.
Cheers,
phunkyfish
is it possible to write something like this:
into an external file like http://myserver.com/mychanel.m3u ? or .ts or .foo or another kind of extension...
and later insert  that link into the main m3u of the SimpleClient
Like that:
#EXTM3U
I'd need to divide them because the part containing #KODIPROP is not static and has to be created in a separate server
(2021-02-01, 20:29)Evandro75 Wrote: [ -> ]Hi,
Like that:
#EXTM3U
No, that is not possible. It must all exist in a single file.
