Full Version: Certificate for mirrors.kodi.tv expired today
just wanted to let you know that your certificate for https://mirrors.kodi.tv seems to have expired today. I can't access it per browser and kodi can't download any updates (throwing a curl error)
(2020-04-17, 21:32)AllesMeins Wrote: [ -> ]just wanted to let you know that your certificate for https://mirrors.kodi.tv seems to have expired today.
Thanks, we'll have a stern talking to whoever is handling these things. Big Grin
just my luck that I decided to do a fresh install of kodi today and found out that add ons are failing to install due to invalid cert on mirrors.kodi.tv
I tried to download the zip file from mirrors.kodi.tv and got the message "It’s likely the website’s certificate is expired, which prevents Firefox from connecting securely. "
(2020-04-17, 22:18)tnkrer Wrote: [ -> ]just my luck that I decided to do a fresh install of kodi today and found out that add ons are failing to install due to invalid cert on mirrors.kodi.tv
Tried to install the Embuary skin for Emby today and got "Installation Failed" error messages. Uninstalled & reinstalled Kodi and lost all my fancy customization for nothing as it has solved nothing. Found this in the logs : "Failed: Peer certificate cannot be authenticated with given CA certificates", copied/pasted the URL in my brower, got an SSL warning and read in Firefox that the certificated expired today Sad
I just registered to let you know too. This issue led to a quite unsatisfying installation experience. Wink
Maybe an option to let users specify if they would like to use curl -k on some URLs could fix that.
Should be back online now. Please check.
(2020-04-17, 23:09)Karellen Wrote: [ -> ]Should be back online now. Please check.
Yes, looks good for me - thanks for the fix!
Thanks! Works now!!!
Is this the reason all the 24/7 tv shows stopped working?
Karen
(2020-04-18, 22:13)Texasgal1924 Wrote: [ -> ]Is this the reason all the 24/7 tv shows stopped working?
Nope.
