Doesn't work for Hotstar US. Bummer
get an error trying to install the repo
(2020-04-22, 21:53)prateek33 Wrote: [ -> ]Doesn't work for Hotstar US. Bummer
Currently it's working in india only with indian hotstar account. You can use with vpn
(2020-04-24, 20:21)markeymark Wrote: [ -> ]get an error trying to install the repo
You need to install repo first and then install add-on from repo. You can find installation instruction
here
(2020-04-29, 17:39)botallen Wrote: [ -> ]You can use with vpn
Do not start suggesting to use a VPN to people, it doesn't sit well with our
VPN policy (wiki).
i am getting an error "background Service crashed" after installing this addon. Can someone help ?
My installation works fine. But while playing any show or movie, audio stops at every 10mins or so and the video continues. Only way to bring back the audio is to go back and reopen the same show and forward to last watched position. Any idea how to fix it?
(2020-04-19, 07:53)botallen Wrote: [ -> ]
Subscription Required
Subtitles is not showing, already enabled, Indonesian language, the movie is TFTWS.
any idea how to fix it?
Does it work for kodi on raspbery pi 3 ? its failing to get installed for me.
Why does it only support for 2.0 dolby audio. On the original app it supports 5.1 or even atmos
The live tv shows an error "subscription error".
I had login successfully but the channels are not working. When I open channel nothing happens
Hi
I live in Thailand and can watch Disney+ Hotstar from laptop or PC via web browser. I just finished to add Hotstar on my Raspberry Pi 3.
Log-in window can show only half second then gone.
How to change hotstar.com/in/activate to hotstar.com/th/activate?
(2021-06-27, 14:41)paritoshec Wrote: [ -> ]The live tv shows an error "subscription error".
I'm getting the same error for Live TV
