2020-04-20, 22:56
Currently, and this is new since (I think) I updated my system, instead of just marking shows etc as watched, episodes are hidden. How do I stop that?
(2020-04-20, 23:00)Karellen Wrote: [ -> ]From the sideblade menu, ensure you have All Videos active and not Watched or Unwatched... https://kodi.wiki/view/Basic_controls#Sideblade_Menu
(2020-04-21, 02:10)the_other_guy Wrote: [ -> ]click on movies or tv shows and it is on the left sideSadly not. I can at least get the menu now I have more information, but it doesn't have the "All Videos / Watched / Unwatched" entry mentioned in the wiki page.
(2020-04-21, 20:25)pkscout Wrote: [ -> ]It would be helpful if you could post a screen shot then.
(2020-04-21, 22:46)Nope666 Wrote: [ -> ]As Hitcher said, you're not in the right place. To have the option to change between watched, unwatched, and all you must either be in the TV Shows area or Movies area. If you have neither of those options, then either you turned them off in the skin settings or you have not scraped any of your TV shows or movies (meaning you are what is called file browse mode). Quit Kodi and restart it. If you don't have TV shows and/or Movies in the main menu on the left, you have to fix that first.(2020-04-21, 20:25)pkscout Wrote: [ -> ]It would be helpful if you could post a screen shot then.which is exactly what I described previously.
(2020-04-21, 23:41)Hitcher Wrote: [ -> ]You're not at the movie level though.
(2020-04-22, 00:17)pkscout Wrote: [ -> ]As Hitcher said, you're not in the right place.
(2020-04-22, 11:38)Nope666 Wrote: [ -> ]Yes I am.No you're not. We all know exactly where you are, and you are not in the Movie Library. You are in File Browser mode.
(2020-04-22, 11:45)Karellen Wrote: [ -> ]I was told "If you go to the TV Show (or Movie)" which I did. If the language being used in either the skin or on this forum is wrong, don't blame me. I've "gone into the Movie" section. I pressed "Movies" so that's where I will be, right? Or should I be trying to find some other hidden menu somewhere? To be clear, in the area where you can edit which "Main menu items" appear, there is exactly ONE item called Movies, which is enabled, and which I then go into from the main menu. Then I end up in the area which I have described and posted a screenshot of. I would imagine that this is the "Movies" section which I was told to enter. No?(2020-04-22, 11:38)Nope666 Wrote: [ -> ]Yes I am.No you're not. We all know exactly where you are, and you are not in the Movie Library. You are in File Browser mode.
