Full Version: Audio Profiles (for Kodi 18 and later)
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18
Quote:does not work. nothing triggers i.e. on onScreensaverActivated with this add on. meh
This is my cron job that works:
54 21 * * * kodi-send --action "RunScript(script.audio.profiles,1)" >> /storage/.kodi/userdata/profile.log
(2024-08-14, 01:46)JonnyGators Wrote: [ -> ]This add-on doesn't work!
Please make a version that does!
If you're hoping for help, this isn't the way to get it.  The addon works fine (I use it every day).  If you just want to bitch, then fine, you've done that.  If you want help, you need to post details of your problem and debug logs showing the problem you are having.
(2024-08-16, 19:33)pkscout Wrote: [ -> ]
Not sure who's fault it is, not sure I care anymore.  But LibreElec devs have decided they know better than anyone else that one shouldn't use the audio output on their audio players, and have added barriers to enable it.  This add-on was mentioned with promises of using it being able to enable the output.  It doesn't.  Hence my complaint.
I still find it ridiculously stupid that one has to manually edit a config file just to enable the option to use an audio output on an audio player, rather than the option to use it being present by default.  But that's hardly the fault of this add-on.
CoreELEC 21.1 Ugoos AM6B Plus
Been using this Add-on for sometime now to switch audio between the SPDIF (Headphones) and the HDMI (TV) outputs on the Ugoos.  Working really well up until recently, I'm getting audio from both the HDMI and SPDIF Outputs at the same time when the SPDIF mode is used.  But only with some videos.  I did not even know it was possible to have audio from both outputs at the same time!
Any ideas why audio from both?
TIA
EDIT:  Debug Log of Video Below with only SPDIF Output enabled.
Here is the MediaInfo of the Audio from a problem video:
Audio
Format                                   : E-AC-3 JOC
Format/Info                              : Enhanced AC-3 with Joint Object Coding
Commercial name                          : Dolby Digital Plus with Dolby Atmos
Codec ID                                 : A_EAC3
Duration                                 : 37 min 58 s
Bit rate mode                            : Constant
Bit rate                                 : 768 kb/s
Channel(s)                               : 6 channels
Channel layout                           : L R C LFE Ls Rs
Sampling rate                            : 48.0 kHz
Frame rate                               : 31.250 FPS (1536 SPF)
Compression mode                         : Lossy
Stream size                              : 209 MiB (3%)
Language                                 : English
Service kind                             : Complete Main
Default                                  : Yes
Forced                                   : No
Complexity index                         : 16
Number of dynamic objects                : 15
Bed channel count                        : 1 channel
Bed channel configuration                : LFE
(2024-11-04, 23:52)gregeeh Wrote: [ -> ]Hi,
You're probably better off posting this in the Linux support area:
https://forum.kodi.tv/forumdisplay.php?fid=52
This add-on doesn't do anything fancy other than load a bunch of saved settings.  If you're getting odd behavior from Kodi, the Linux support area is going to be the place that someone will see and answer your question.
