Full Version: favourites problem
Is there a way to add to the menu (as you would in Nox)
because there is a limited amount of slots you can customise
but it would seem in Tajo that you cannot change them from their original function anyway?
pictures will do pictures even if you change it for example.
and for some reason Tajo will not shortcut to a favourite source
it will take you to the 'add files' page that you would have added the source to favourites
I am having the same issue....When you try to set a folder on the homepage to a custom favorite or other folder it will not go to that set area. It will just go to a default page every time.
(2020-08-04, 01:29)chrono727 Wrote: [ -> ]I am having the same issue....When you try to set a folder on the homepage to a custom favorite or other folder it will not go to that set area. It will just go to a default page every time.
To update this post it looks like if you make a sub menu item it links correctly....it just doesnt seem to work with the main link.
