Full Version: False Identifications - Compare Movie Length with File Length
TMM does a good job scrapping automatically movies with a correct name, but sometimes it can does a false identification.
Would be really helpfull to have a filter where you can compare IMDB/TMDB duration with Video File Duration, once the media info has been done.
That filter should include a set up to show movies which duration difference is higher than X minutes.
That way, you can afterwards review those movies manually to see if there is a false identification.
good idea, but not completely doable. There are many movies out there with different cuts/editions where the runtime differs (heavily). Most of the meta data providers just (IIRC all except imdb) only list one runtime - so the chance to get a false positive here is big..
Hi mlaggner,
I understand there are director's cut editions and some others, so we might have false positive for sure, but at least you can discard a lot of movies that are correct and that way, we solve most of the problem.
Well... It was an idea that could be helpful.  I guess you have some other features to apply first, but in case you consider it interesting, it will be a good one!
Regards,
