Full Version: chorus2 web search not working: missing /all/ makes the search hang
Hello,
the search bar does not work on iphone. It seems there is a /all/ missing from the query.
Searching the word flute i got a response from PC (windows10): http://192.168.1.75/#search/all/flute
The same in iphone (Safari) does not get any answer and the url is: http://192.168.1.75/#search//flute
If I manually add /all/ everything works.
The same can appen from PC if you reach the search with the url: http://192.168.1.75/#search
From there, performing any search does not automatically  include the "/all/" part and hangs.
I am running raspberrypi 3b+ with OSMC Kodi latest available.
Thank you very much!
Carlo.
