(2020-04-28, 21:34)redreaper5820 Wrote: [ -> ]I used DroidTV by Digital High to make this android TV skin.
I am not very good at coding kodi skins.
The skin works on Kodi v18.6 Leia
https://github.com/Redreaper5820/KoDroidTV
I have put the zip for installing the skin in releases.
Any help is really appreciated
Thank you
Had a quick look, neat set up , cant add anything via zip , addon browser doesnt work , cant add surce for library as videos button in media section wont open , good luck with it , its definately a refreshing , unique looking layout.
How you doing with this , I have downloaded the skin from Github a couple of times, still unable to test yet as , the add-on browser locks up as soon as you try to open it so am unable to install any zip files and the media section does the same when I select videos , so am unable to add any content to the library.
(2020-05-01, 20:45)ontap Wrote: [ -> ]How you doing with this , I have downloaded the skin from Github a couple of times, still unable to test yet as , the add-on browser locks up as soon as you try to open it so am unable to install any zip files and the media section does the same when I select videos , so am unable to add any content to the library.
Yeah, I have been trying to get the addon browser part. Hopefully I'll get it to work.
Well the media section I'll check, but to further clarify by media section you mean the adding of media setting or the media library part where you select the media to play ?
