2020-04-30, 18:37
2020-04-30, 19:41
(2020-04-30, 18:37)mdisbrow Wrote: [ -> ]Looking to get a gt 1030 or 1050 for media.I have to 1060 and no complaints. ATM the stable version of Leia doesn't handle 10 bit (the underlying DX which Kodi depends doesn't), but there is many work-rounds, forks etc. that do; the future is bright if you want to investigate Matrix.
2020-04-30, 23:55
(2020-04-30, 19:41)PatK Wrote: [ -> ](2020-04-30, 18:37)mdisbrow Wrote: [ -> ]Looking to get a gt 1030 or 1050 for media.I have to 1060 and no complaints. ATM the stable version of Leia doesn't handle 10 bit (the underlying DX which Kodi depends doesn't), but there is many work-rounds, forks etc. that do; the future is bright if you want to investigate Matrix.
I did stumble onto the kodi 19 Matrix thread. Seems the way to go if I want a htpc. I eventually just opted to get an odroid n2 and not worry about it. CoreElec has everything working without much fiddling. I still may set up an htpc if I can find a 1030 or 1050 for less than $40.
