Full Version: Amber 3.2.65: Missing button slider inside PVR channelgroups management
Hi!
There's something I can't do with Amber inside settings -> PVR -> channelgroup management. There's a button/slider to hide/unhide a group. Here you can see it with default skin:
https://drive.google.com/file/d/1QdQNU64...sp=sharing
With amber, that button is only a button, it hasn't the slider, and pressing the button does nothing:
https://drive.google.com/file/d/1bBaEISZ...sp=sharing
bye!
(2020-05-01, 11:18)peque Wrote: [ -> ]Hi!
bye!
@peque , thanks for reporting this.  In the next update, I will change the button type so that it is clear whether the group is hidden or not.  Please remember to press enter (click) on a group before going to the button to hide/unhide it.  Thanks.
Regards,
Bart
Yes! That's the way it works.
I'll keep an eye in that update.
(2020-05-04, 19:40)peque Wrote: [ -> ]Yes! That's the way it works.
@peque , 3.2.66 is already on GitHub and the Amber repo.
Regards,
Bart
Yes! Fixed. Thanks a lot.
Mmmm... Now recent series/movies shelves are empty (pvr recent channels are ok)... Could it have to do with this update? Or is it me?
I've just rolled back to 3.2.23 and it's working, so its has to do with this update...
(2020-05-05, 23:59)peque Wrote: [ -> ]Mmmm... Now recent series/movies shelves are empty (pvr recent channels are ok)... Could it have to do with this update? Or is it me?
@peque, I fixed that as well in version 3.2.67.  it is already on GitHub and the Amber repo.
Regards,
Bart
Fixed also.
Thanks again.
