hello,
i tried playing demo videos with window media player on windows 10 and it outputs (lights the atmos sign) on my onkyo TX-NR3030. However, when I play through kodi leia(enabled wasapi output and passthrough, including dolby atmos,etc.) it doesnt output atmos (doesnt lit the ATMOS sign) on my avr.
Did I miss something on my set up? Help please?
The instructions are here...
debug log (wiki)
1.
Enable debugging in Settings>System Settings>Logging,
2.
Restart Kodi
3.
Replicate the problem.
4.
Upload the log to
Kodi Paste Site manually or use the
Kodi Logfile Uploader. (wiki) With either method post the link to the log back here.
If you are using the Advanced Method ensure you have correctly created and applied the
advancedsettings.xml file (wiki)
In both instances, you should see the word
DEBUG throughout the log.
Do NOT post your logs directly into the forum. Use the Kodi Paste Site. Post the link to your pasted log in the forum
(2020-05-10, 10:15)Hitcher Wrote: [ -> ]To receive meaningful assistance you will need to provide a full debug log.
The instructions are here... debug log (wiki)
1.Enable debugging in Settings>System Settings>Logging,
2.Restart Kodi
3.Replicate the problem.
4.Upload the log to Kodi Paste Site manually or use the Kodi Logfile Uploader. (wiki) With either method post the link to the log back here.
If you are using the Advanced Method ensure you have correctly created and applied the advancedsettings.xml file (wiki)
In both instances, you should see the word DEBUG throughout the log.
Do i need to do this even if I'm not getting any error message?
If you want us to help you you do.
2.Restart Kodi
tried pasting the log file but the site says "Document exceeds maximum length"
Did you start Kodi, play video briefly, and then quit Kodi?
(2020-05-10, 14:31)Hitcher Wrote: [ -> ]Did you start Kodi, play video briefly, and then quit Kodi?
yes, i actually played two atmos videos to check but it is still the same. When I played the videos through VLC and WMP it outputs Atmos but not on kodi leia.
(2020-05-10, 11:53)Hitcher Wrote: [ -> ]If you want us to help you you do.
it exceeds the max length....can I cut the log into two?
Are you sure you have pass-through enabled -
Creating audio stream (codec id: 86060, channels: 8, sample rate: 48000, no pass-through)
(2020-05-10, 17:19)Hitcher Wrote: [ -> ]Are you sure you have pass-through enabled -
yes 100% sure, that's why I am wondering. also enabled all others below the pass-through tick option
You haven't enabled 'Sync playback to display' have you?
