2020-05-04, 00:11
I've been trying to use the Anaglyph Red/Cyan stereoscopic mode with my 3D MVC mkv's. For some reason Kodi (on Windows 10 and Xbox One X) doesn't actually render the correct red/cyan frames. Instead it is just rendering a standard 2D image, despite the Kodi UI clearly being in stereoscopic mode when enabled.
You can see in the image below how it renders with Kodi.
https://ibb.co/WsQNVc3
To verify I also ran the same MKV file in Stereoscopic Player which renders the mkv just fine in anaglyph red/cyan (below).
https://ibb.co/3FzjF8r
Is this a bug? Bad setting?
