2020-05-04, 21:51
hello, i'm french so excuse me for my english. I tell you my problem. I use kodi18.6 léa in 64bits with PowerDVD19 in 64 bits and virtual clone drive in 32bits to edit my bluray films which are in ISO. When I read in kodi, PowerDVD launches but nothing happens the virtual player of virtual clone drive appears well in powerDVD but it is empty does anyone have a solution to my problem. I am attaching my playcorefactory that I did while reading you on the forum. Thank you all.
<?xml version="1.0" encoding="UTF-8"?>
<playercorefactory>
<players>
<player name="POWERDVD" type="ExternalPlayer" audio="true" video="true">
<filename>C:\Program Files\CyberLink\PowerDVD19\PowerDVD.exe</filename>
<args>/"{1}"</args>
<hidexbmc>true</hidexbmc>
<hideconsole>true</hideconsole>
<warpcursor>none</warpcursor>
</player>
</players>
<rules action="prepend">
<rule filename="*.iso" player="PowerDVD"/>
<rule filetypes="mkv|iso|bdmv|wmv|mpg|ifo|ts|m2ts" player="POWERDVD" />
<rule filetypes="mp3|flac|wav|wma" player="PAPlayer" />
</rules>
<rules name="system rules">
<rule name="mms/udp" protocols="mms|mmsh|udp" player="VideoPlayer" />
<rule name="lastfm/shout" protocols="lastfm|shout" player="PAPlayer" />
<rule name="rtmp" protocols="rtmp" player="videodefaultplayer" />
<!-- VideoPlayer can play standard rtsp streams -->
<rule name="rtsp" protocols="rtsp" filetypes="!(rm|ra)" player="PAPlayer" />
<!-- Internet streams -->
<rule name="streams" internetstream="true">
<rule name="aacp/sdp" mimetypes="audio/aacp|application/sdp" player="VideoPlayer" />
<rule name="mp2" mimetypes="application/octet-stream" filetypes="mp2" player="PAPlayer" />
</rule>
<!-- DVDs -->
<rule name="dvd" dvd="true" player="VideoPlayer" />
<rule name="dvdimage" dvdimage="true" game="false" player="VideoPlayer" />
<!-- Only VideoPlayer can handle these normally -->
<rule name="sdp/asf" filetypes="sdp|asf" player="VideoPlayer" />
<!-- Pass these to VideoPlayer as we do not know if they are audio or video -->
<rule name="nsv" filetypes="nsv" player="VideoPlayer" />
<!-- pvr radio channels should be played by VideoPlayer because they need buffering -->
<rule name="radio" filetypes="pvr" filename=".*/radio/.*" player="VideoPlayer" />
</rules>
</playercorefactory>
<playercorefactory>
<players>
<args>/"{1}"</args>
</player>
</players>
</rules>
</rule>
<!-- DVDs -->
</rules>
